Old 09-05-2012, 10:24 PM   #1
skoffice
skoffice's Avatar
Blazer Body Mount Question?????
OK I am fighting these body mounts on this darn '71 Blazer. Can anyone verify the order the bushings go from front to back? This blazer is for a customer and he bought the Energy Suspension kit years ago, and has since lost the paper work. What I could gather from Energy's website (their .pdf instructions online seemed to leave out the last 3 positions of body mounts) was obviously small diameter bushings for the core support, then the thick, large diameter bushings for the front cab (position 2) and the rest are all the large diameter thin bushings. I have it laid out this way currently but the position 3 bushing seems to have a large gap as if it were to need a thick one as well. This frame has had a ton of welding and boxing done to it so there is always that possibility that it's tweaked, because when the bushings are tightened the doors wont close. Any help would be awesome!!! Thank you fellas!
1964 C10 Shortened Shortbed Cammed LQ9 P&P
1967 C10 Trophy Truck BB 438 (soon to be worked on again)
skoffice is offline   Reply With Quote
Old 09-06-2012, 10:45 PM   #2
69-72
69-72's Avatar
Re: Blazer Body Mount Question?????
Check out the poormans assembly manual. Aka LMC truck catalog
1969 Chevy Custom Camper 3/4 ton Rust free survivor
1972 Chevy Blazer CST 4x4 Almost Rust free survivor
1972 GMC Jimmy 2wd Undergoing surgery
69-72 is offline   Reply With Quote
Old 09-07-2012, 04:17 PM   #3
My3Sons!
My3Sons!'s Avatar
here is the link: http://www.lmctruck.com/icatalog/cb/full.aspx?Page=37
My3Sons! is offline   Reply With Quote
Old 09-11-2012, 09:56 PM   #4
ol'blu72
I did this not too long ago. All the rears are the same, you will need to shim to make up the gap or to where the body is straight and doors close. My kit came with shims (square metal plates with holes) and if I remember right most positions needed none and I remember one spot needing at least 2.
Brad
72 Blazer CST 350/350/205
ol'blu72 is offline   Reply With Quote
