Old 09-26-2012, 10:49 AM   #1
Dale99
frame size
So Ive been trying to find a blazer or burb 4x4. I know the blazers are on the same frame as a SWB truck. I did some quick searching and it appears the burb is on its own frame? It does not share it with a LWB truck? Is this correct?
I've found some nice burbs, but all were 2wd.
Dale99 is offline   Reply With Quote
Old 09-26-2012, 01:12 PM   #2
vectorit
What?
vectorit's Avatar
Re: frame size
Yep, burb frames are specific to the Suburban.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 09-26-2012, 01:15 PM   #3
Dale99
Re: frame size
Thanks!!!
2008 Sierra k3500 LMM
1994 s10 blazer 4x4
1991 Camaro Vert Rusted in Half RIP
1972 Jimmy 4x4 L05,4L60E,np205http://67-72chevytrucks.com/vboard/s...d.php?t=546364
1967 C10 L6/3tree(dads truck)
Old 09-27-2012, 11:30 AM   #4
Hart_Rod
Hart_Rod's Avatar
Re: frame size
Frames are the same except for the rear body mounts (very front mounts are identical) and the rear ends of the frame. The burbs rear frame is used to mount the bumper. You can convert a truck frame, but it takes a little work.
Hart_Rod is offline   Reply With Quote
