Old 10-05-2012, 09:53 AM   #1
HotRod434
HotRod434's Avatar
Headlights, swapped around.
I just bought 4 new Silverstars for my '86 and was wondering, any of you guys ever put the dim's on bottom and brights on top? I noticed the lights in it now are right opposite. Just wondering which works best.
- '86 Silverado "Camper Special". 3/4 Ton, Factory 454/400 turbo, w/4.10 gear and 76k original miles.
HotRod434 is offline   Reply With Quote
Old 10-05-2012, 02:14 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Headlights, swapped around.
People do it. Just depends on taste. Make sure they are aimed right and you will be ok
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 10-05-2012, 02:42 PM   #3
C-10 simplex
Better yet, is there a way to have all on at the same time if you switch to hi-beams?
i don't think it's illegal?
C-10 simplex is offline   Reply With Quote
Old 10-05-2012, 05:33 PM   #4
Your41Plague12
Your41Plague12's Avatar
When I turn my high beams on, all 4 lights stay on. It switches filaments in the low beam bulb and also lights up the high beam bulb.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 10-05-2012, 09:08 PM   #5
Gordonr1973
Home Built '87
Gordonr1973's Avatar
LMC sells a harness to do this. It's in my 87 build thread near the end.
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 10-05-2012, 11:39 PM   #6
HotRod434
HotRod434's Avatar
All 4 of mine are on when i hit the high beams also. Figured id put the high beams on top, i know im gonna get bright lighted with them on dim cause i have silverstars in my S10 and so i get it all the time.
Old 10-09-2012, 10:06 PM   #7
motornut
78K & 79C Jimmys
motornut's Avatar
did it to the 87 and 88,you have to bend the corner tabs in the buckets,thats it,move wires
I found it easier to aim the lights,seemed more light "on" the road
and yes all four stay on
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
