Old 09-29-2012, 06:17 PM   #1
Nightmare70
2wd rear blazer coils HELP
Hey guys I got a new project 70 blazer I lowered it with rear coils 4" CPP these were crap bottomed out on everything and bounced up and down. I switched to a 3" Western chassis these are WAY better support the blazer alot better no bouncing and squishiness, But with my two teen kids in it the blazer bottoms out. I know its the extra weight but I was wondering if there was something I could do to keep it low and still support the weight? Something other then bags? Thanks for any help
Nightmare70 is offline   Reply With Quote
Old 09-29-2012, 11:26 PM   #2
andrewmp6
Re: 2wd rear blazer coils HELP
Did you trim the bump stops after you lowered it ?I know you don't want bags but they do make a helper one that goes inside the coil spring.
Old 09-30-2012, 09:21 AM   #3
cdowns
cdowns's Avatar
air shocks is what i wuld try
Old 09-30-2012, 03:49 PM   #4
Nightmare70
Yea but coils support the weight and shocks just keep it from bouncing as much.So I'm not sure a stiff shock would make all that much difference?
Old 09-30-2012, 04:55 PM   #5
cdowns
cdowns's Avatar
talk to people who know what an air shock is and people that have used them // they ARE NOT regular shocks that you have mistaken them for
Old 09-30-2012, 05:09 PM   #6
Nightmare70
Yea I've had several cars with air shocks I'm familiar with how they work. They still work like a shock just one you can adjust the firmness on. So yea I guess I could buy them over fill them so theres no give and run them like that. But I was curious if anyone else had a similar issue with a blazer and what kind of coils there running in the back.
Old 10-04-2012, 07:43 AM   #7
lolife99
67-72 parts collector,…
lolife99's Avatar
I ran 6" drop coils from ECE on my 2wd blazer when it was static dropped.
It did bottom out with a truck load of people in it.
Removing the top helped a little, since the back raised up about 1".
I didn't find the answer until I bagged it.
I installed a bolt-in c-notch.
That cured the problem.
Keith
Convert to disc brakes.
Old 10-07-2012, 01:47 AM   #8
Narxoleptic Customs
C notch...
Narxoleptic Customs is offline   Reply With Quote
Old 10-12-2012, 02:04 AM   #9
Andy4639
Old member
Andy4639's Avatar
Wink Re: 2wd rear blazer coils HELP
I have a 71 chevy LWB with 4" drop coils. I put the helper bags inside the coils and it made a world of differance. I can load it up now and never bottom out. I have no c-notch either and can't see cutting the frame as so many do.
I ran my air lines to the back bumper and installed the shreader valves as my tag bolts.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 10-12-2012, 09:40 AM   #10
4oldcars
4oldcars's Avatar
Hey Andy - - where did you get your helper bags from? Was this cost effective compared to just using air bags on the rear?
4oldcars
Driving:
1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado
The ones I let go:
1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed
4oldcars is offline   Reply With Quote
