Old 10-23-2012, 10:34 PM   #1
xfsketch
72 fleetside longbed 350
Cool May have the money to do this question.
I may be able to finally afford to do what I want to my truck. I used to want to drop it on airbags but now Im kicking around turning it into a 4x4! It is a 72 lwb 1/2 ton and I read on here the 3/4 ton frames are pretty much the same as the 1/2 tons. my question is... Do I half to have leafs all around to make it 4x4? Could I just keep the coil suspension and still lift the truck?
xfsketch is offline   Reply With Quote
Old 10-23-2012, 11:34 PM   #2
Billett
Billett's Avatar
Re: May have the money to do this question.
lifting a 2wd of this year doesn't usually work, but it is possible with custom fabrication. Look up prerunners on this site to see some examples. As far as making it 4wd it is much easier to find a 4x4 frame and swap the body over than to convert a 2wd frame to 4wd.
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 10-23-2012, 11:50 PM   #3
xfsketch
thanx I will check into it. Appreciate your info
Old 10-23-2012, 11:56 PM   #4
Billett
Billett's Avatar
I looked into the same thing a while back. This thread in particular might interest you. It has pics!
http://67-72chevytrucks.com/vboard/s...d.php?t=511349
Will
2024 Toyota Sienna
Old 10-24-2012, 07:04 AM   #5
xfsketch
thanx billet!
