Old 10-24-2012, 01:22 PM   #1
Mr Chevorlet
Rusty Nuts
Mr Chevorlet's Avatar
windshield washer container mounting
Well when i pulled the truck apart i removed the washer botle bracket ,so i thought but i am looking at the drivers side fender and there are no screw holes in that area at all for that. and none on the other side, it is a 67 and i do have the new hose ran from the pump down the drivers side where i thought i remember it going. And no i didnt fill in the holes and they are the stock fenders. I must be loosing it because i have not had that many beers yet. and less you all can tell me another location it would of been on a 67 some one else has swapped my truck for another while i was'nt looking. Thanks
(Clever Missouri) Southwest
Larry
Mr Chevrolet
My Build, The Marathon Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=604414
Mr Chevorlet is offline   Reply With Quote
Old 10-24-2012, 02:47 PM   #2
chewychevy67
Re: windshield washer container mounting
on a 67 they mount to the rad support. at least my 67 gmc does.
chewychevy67 is offline   Reply With Quote
Old 10-24-2012, 02:51 PM   #3
SS Tim
SS Tim's Avatar
The only variation I can think of right now are the later trucks with the left aux battery. On those trucks the botttle was moved to the right fender. Not sure if this applies to the '67s though. Its in the assembly manual, I think.
SS Tim is offline   Reply With Quote
Old 10-24-2012, 03:48 PM   #4
Mr Chevorlet
Rusty Nuts
Chewy i will look on the radiator suport, and ss my build manual shows on the fender or the firewall by the coloum, but i have never seen one there on any truck. but i will look in it again because you know how these books are put togther.
Larry
Mr Chevrolet
Old 10-24-2012, 05:33 PM   #5
FirstOwner69
FirstOwner69's Avatar
My early 69 has it mounted on the radiator core support above the voltage regulator also. The washer bottle bracket for the core support mount is also slightly different from those I've seen for mounting on the fender in order to stand out from the core support enough for it to clear the top of the core support. Here's a picture showing the 2 brackets. The one on the right is the one used on the earlier model years, and the one on the left is the one I've seen on the later models with the fender mount.
Which bracket do you have? Bet it's the one on the right.
See additional picture showing it mounted on the core support in post 7 below.
FirstOwner69 is offline   Reply With Quote
Old 10-24-2012, 05:38 PM   #6
whoryou1979
whoryou1979's Avatar
Some also mounted to the driver side firewall
All Day Every Day
'72 C20 Cheyenne Custom Camper
http://67-72chevytrucks.com/vboard/s...d.php?t=549132
whoryou1979 is offline   Reply With Quote
Old 10-24-2012, 05:38 PM   #7
FirstOwner69
...and here is a picture of the bottle mounted.
Old 10-24-2012, 08:34 PM   #8
Mr Chevorlet
Rusty Nuts
Ok guys it does go on the drivers side core support . And first owner 69 I do have the bracket on the right side of your pick. Already have it mounted. Thanks guys.
Larry
Mr Chevrolet
Old 10-24-2012, 08:42 PM   #9
100%Chevy
This is what I did on my 68-
The one by the radiator is my over-flow bottle and the one on the fender is my washer bottle.
If you look close,there are three small punch marks on the fender telling you where to drill for the mounting holes.
The mounting brackets were used on all GM models thru the 60's on up to at least 79.Easy to find in the junkyards.
Uploaded with ImageShack.us
Mike./
100%Chevy is offline   Reply With Quote
Old 10-25-2012, 09:59 AM   #10
Mr Chevorlet
Rusty Nuts
100%chevy thats a good idea. I have extra bottle and brackets form others i have parted out, i might go ahead and do that. thanks
Larry
Mr Chevrolet
