Coolant overflow tank
Just found this site and what at great sorce of information, thanks to all. My swap is a 5.3 into 1965 1 ton dually hauler custom built by my father in law in the late sixties. I am using a 3 row Champion aluminum radiator with a cap on the passenger side tank, do I need to run the factory overflow tank ?
I am running my steam line to a fitting on the tank just below the radiator cap that is higher then the engine. Any help would be great. |
Truck and auto performance nut
Re: Coolant overflow tank
just remember when filling with coolant fill the radiator then fill the motor thru the upper radiator hose. filling thru the radiator will not fill the block.
oh...and not sure it matters what overflow tank you run?
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
If I read this correctly, you're planning on running the engine steam line to the radiator overflow port on the radiator neck? If so, I don't think that will work.
If it is a port on the passenger side tank you should be fine. You probably don't need an overflow tank...I have one but it never sees any fluid. Besides, there were no "stock" overflow tanks for these trucks that I know of.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold ![]() 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold ![]() 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! ![]() 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold ![]() ![]() ![]() 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70!!! (Sold) ![]() 2003 K2500HD 8.1/Allison1000/NP263 ![]() |
