Old 10-01-2012, 06:45 PM   #1
Drewbee
WTB 69 Rear spring hangers
Hey,
I am in need of 69 rear spring hangers. I have the front, but the rear's are year specific. They are shorter than 71-72. I think even the 70's are slightly different. If someone has these it would make my day!
Drewbee is offline   Reply With Quote
Old 10-01-2012, 07:13 PM   #2
Undone
Re: WTB 69 Rear spring hangers
I have a set from a 69 gmc leaf spring rear. 45.00 shipped
Undone is offline   Reply With Quote
Old 10-01-2012, 07:14 PM   #3
Drewbee
Saweet! Do you have pictures?
Old 10-01-2012, 07:51 PM   #4
Undone
I'll get you some tomorrow.
Old 10-01-2012, 07:57 PM   #5
Drewbee
Thanks a bunch!
Old 10-01-2012, 08:15 PM   #6
mrdana60
Make sure you say 4x4 also. Sorry the ones I sold you was wrong.
mrdana60 is offline   Reply With Quote
Old 10-02-2012, 10:42 AM   #7
Drewbee
Good point thanks! And don't worry I'll finish cleaning the ones I bought from you and sell them on here. Someone will get a good set of rear spring hangers for 71-72.
Old 10-02-2012, 10:43 AM   #8
Drewbee
If the 2wd is leaf springs....does it matter if its 2wd or 4wd? I do have a 4wd and looking to get this frame done.
Old 10-02-2012, 11:49 AM   #9
mrdana60
2wd will be shorter. You could use them but you would need lift to take up slack from the shorter hangers. The 4wd hang down past the frame where a 2wd is closer to the frame.
Old 10-02-2012, 12:18 PM   #10
Drewbee
Then I definitely need 4x4.. I may have to start a new thread to add that in the title.
Old 10-02-2012, 06:27 PM   #11
Drewbee
Evening bump...anybody got any 4x4 rear leaf spring hangers for a 69
Old 10-03-2012, 12:24 AM   #12
Drewbee
late night bump
Old 10-03-2012, 03:03 PM   #13
Drewbee
mid day bump.. still looking for 1969 4x4 rear spring hangers. These can be off a suburban, or a K5 as well.
Old 10-03-2012, 10:59 PM   #14
Drewbee
Nobody has these?
Old 10-04-2012, 01:13 AM   #15
Jdubs71
Jdubs71's Avatar
Originally Posted by Drewbee View Post
Nobody has these?
I had the same problem you did, 69 is one year only, 70 is one year only and 71 & 72 are the same. I have a 70 K5 and the frame is stamped in front of and behind the hanger to keep it from moving, see pic. As you can see the 71/72 hanger would not work for me. If your frame is flat where the hanger mounts you should consider using 71/72 hangers, much more solid. the holes are off but you can re-drill them to make it work. If your frame is like mine then you're screwed and will have to wait til someone comes along and can help. Unfortunately I became an expert in spring hangers (not by choice). Burb's, K5's and K10's all use the same hangers and 2wd and 4wd are different If your able to use 71/72 hangers by drilling new holes and you want to go that route let me know, I have a set that I bought before knowing what I know now about spring hangers.
Jdubs71 is offline   Reply With Quote
Old 10-04-2012, 09:05 AM   #16
Drewbee
Thanks Jdubs,
I learned the hard way as well. But I'm going to keep looking for 69 set. Someone has to have a set.
Still looking
Old 10-04-2012, 09:36 AM   #17
Jdubs71
Jdubs71's Avatar
Thanks Jdubs,
Still looking
Good luck, they're out there just hard to find. They usually stay with the frame or get scraped. I never looked into earlier models, 67/68 might work for you I just don't know for sure.
Old 10-04-2012, 12:50 PM   #18
Drewbee
Bump to the top
Old 10-04-2012, 04:14 PM   #19
Drewbee
afternoon bump
Old 10-04-2012, 07:03 PM   #20
Drewbee
evening bump...69 4x4 rear spring hangers
Old 10-05-2012, 01:11 AM   #21
Jdubs71
Jdubs71's Avatar
Saw this tonight. Good deal and you lucked out, because they don't come around often.
http://67-72chevytrucks.com/vboard/s...d.php?t=546133
Old 11-01-2012, 12:11 AM   #22
Blaster1420
Do you still have the 71-72 hangers?
Blaster1420 is offline   Reply With Quote
Old 11-01-2012, 04:25 AM   #23
Jdubs71
Jdubs71's Avatar
Yeah I still have them I will pm you
