Old 06-15-2003, 08:20 PM   #1
alta-aj
Early 60s Posi Rearend
I posted this on the Engine and Drivetrain section as well:
I'm just wondering how good and how desireable a GM part# 3817778 Dana 3.73 Posi (I believe) crown, pinion and differential is. It is curreently in a 62 or so half ton.
Is it swapable into 67-72 trucks?
Al
alta-aj is offline   Reply With Quote
Old 06-15-2003, 09:40 PM   #2
crazy4chevs
crazy4chevs's Avatar
rear
The rear should fit, but if i remmber right the early ones only have 18 spline axles and spiders. The newer 65-66 up had 30 spline axles and spiders. This means that it wont take as much abuse as the others.
70 chev c10 swb fleet
72 grill, sb 400, 2/4 drop.
68 chev c10 swb fleet
Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C
Classic GM Truck Club of Washington
crazy4chevs is offline   Reply With Quote
