Old 11-08-2012, 04:26 PM   #1
not2oldchevy
Help with temp gauge
I am using a autometer #2268 adapter but I can't find a sending unit that will fit. If I drill it out it will be so thin it will snap when I tighten it up. Anybody had this problem?
not2oldchevy is offline   Reply With Quote
Old 11-08-2012, 06:34 PM   #2
JJAB
Re: Help with temp gauge
No , i just did this yesterday. You can drill it out, it does enough meat wher you can drill it out; but be careful. Heres the thing though, if you go to the local parts store to find a temp sending unit to screw into it, you are wasting your money because you dont know exactly what type of temp guage it is for. I went to Oreilly, got a tenp sending unit to screw in, after drilling out with no leaks and the guage ran 250 degrees plus. I know the the reading was wrong because I got a custom tune yesterday too and the tuner's laptop read 199 degrees the whole time. Best thing to do is purchase the autometer sending unit from JEG's that will fit that adapter. This is what i was forced to order. Good Luck!!!!!!!!!!
JJAB is offline   Reply With Quote
Old 11-08-2012, 07:48 PM   #3
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
I drilled and tapped my head. Its very close on size, so you don't have to drill much. Then tap...and screw the sender right in.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
