Old 11-19-2012, 04:18 PM   #1
INSIDIOUS '86
INSIDIOUS '86's Avatar
Pinch seam. Do we need it?
That big ugly pinch seam under our cabs and fender do we need it? Kinda disrupts the flow of the body I want to eventually cut it off. Can I do this and weld the seams granted I keep the drainage grooves. Any body have pictures of this?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 11-19-2012, 05:41 PM   #2
86c20
86c20's Avatar
Re: Pinch seam. Do we need it?
If u are tacking about the one for the rocker then yes u can cut it off and weld the in and outer together if u want. Like y said tho keve the drain there
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
Old 11-19-2012, 06:25 PM   #3
cory d
cory d's Avatar
then your frame and gas tanks will be showing more. time the trim the bottom of the frame and put a tank in the back
cory d is offline   Reply With Quote
