Can I fit a 1.25 spacer on rear with Boss 20x10?
I am going to mount Boss 20x10's with 1.25" spacer on the back of the 67 but the rearend is the wider 70 rearend. Anyone running these sizes? The Boss wheels have a 6.25 Back space, so calculating, it should work. Please tell me your drop and rear tire size too. Thanks.
Re: Can I fit a 1.25 spacer on rear with Boss 20x10?
i used 1 inch off of ebay. 1.25 will push em out too far i bet.
horsepower sells cars torque wins races. "caroll shelby" |
Thanks for the input. What drop and tire size are you running? how much room do you have between the inner wheel well and back side of your tires?
Any other examples of people running Boss 20x10's in the rear? Adapter/spacer sizes?
Bump for more info.
SOLD -77 CHEYENNE SWB, LS SWAPPED -1976 SILVERADO YUBA GOLD/NEUTRAL (2-TONE) |
67-72 parts collector,…
![]() Join Date: Nov 2002
I agree,... a 1" spacer would be better with the wide rearend.
1-1/4" to 1-1/2" for the early narrow rearend.
Old member
I'm running 1/4" spacer to clear inner fender with 20"x10" wheel.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
What rearend you running?
Old member
