Convert from column shift to floor shift
I have one last obstacle to fix and then my GMC should be road worthy. I took it out for a drive and it wouldn't shift in to 2nd or 3rd. I found part of the linkage was rusted solid and in a effort to break it loose, I managed to break the part off the frame. I've read a little about converting to a floor shift and was wondering if anyone has done that? Is there a kit available for my 60 GMC? Any help will be greatly appreciated. Thanks!
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
