Old 12-15-2012, 09:18 PM   #1
JDon99
2wd Exhaust Clearance
Just thinking out loud here. Is there enough clearance for a single 5" exhaust on the 73-87 2wd trucks? Thanks fellas.
JDon99 is offline   Reply With Quote
Old 12-15-2012, 09:54 PM   #2
Pop's C-10
Pop's C-10's Avatar
Re: 2wd Exhaust Clearance
yes & don't do it...
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 12-15-2012, 10:42 PM   #3
INSIDIOUS '86
INSIDIOUS '86's Avatar
Why single? Two 2.5 pipes yield the same with better scavenge less pressure and better sound and can be quieter and yeild better ground clearance. So really not a point
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 12-15-2012, 10:50 PM   #4
JDon99
This exhaust would be on a single turbo setup. Fwiw, two 2.5" pipes flow roughly half of a single 5". Just curious if there is room between the crossmembers and the body for the 5". Thanks for the replies
Old 12-15-2012, 10:54 PM   #5
INSIDIOUS '86
In theory yes but one muffler vs two and the scavenging effect plus velocity makes 2.5 far superior
But yes for turbo get a fat downpipe in there and don't go to long
Old 12-16-2012, 07:36 AM   #6
andrewmp6
What turbo are you going to run?Unless its a diesel 5 inch exhaust is over kill.
Old 12-16-2012, 08:37 AM   #7
JDon99
It would be in the 75-85mm compressor range, lsx engine. There is a guy over on performancetrucks.net that seen a 20 lb/min increase in airflow when dumping his 5" downpipe at the 4" bottleneck in his exhaust. That's a pretty substantial increase in my opinion. That is what got me thinking about the 5" exhaust and if it would even fit under the 73-87.
Old 12-16-2012, 09:20 AM   #8
andrewmp6
How did he measure the air flow differences tho?
Old 12-16-2012, 09:28 AM   #9
bk2life
really he didnt ask for everyones opinions on what you would do. he asked if a 5" sewer pipe will fit. there is room, it'll be tight. time consuming to piece it together, but if its not lowered to much you can make it work.
post some pics.
bk2life is offline   Reply With Quote
Old 12-18-2012, 04:49 AM   #10
JDon99
I would assume that he was datalogging those values.
