Old 12-30-2012, 06:03 PM   #1
hamad
hamad's Avatar
Transmission question, PLEASE HELP
Hello everyone,
I found a great donor truck.I previously asked about swapping my tranny from an auto to a manual. So now i found this great donor truck for a good price. It has a SM465 in it, but runs on a 350, and my truck runs on a 454 with a 700R4 tranny. The question is, if i was to buy this donor truck and swap the tranny, would everything bolt on or are there differences since the motors are different. I imagine the bell-housing wouldn't bolt on. If that is correct, can one of the bell-housings be modified or do i have to buy a whole bellhousing? If so can i please when from where can i find this bell-housing?
Thanks in advance
hamad is offline   Reply With Quote
Old 12-30-2012, 06:09 PM   #2
krazy_texan
krazy_texan's Avatar
Re: Transmission question, PLEASE HELP
I have always been under the assumption that that trans will bolt right up to your big block I think they all share the same bell housing
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 12-30-2012, 06:31 PM   #3
oldgoalie
The bell housings and trans will work. You will probably have to find a flywheel for the 454 I believe they are balanced different than the 350.
oldgoalie is offline   Reply With Quote
Old 12-30-2012, 06:46 PM   #4
hatzie
Moderator
hatzie's Avatar
The bellhousing will fit just fine and the SM465 is a very heavy duty unit.
Get a 454 flywheel and sell the 350 flywheel. I'm not sure that 350 flywheel will even bolt up to the 454... Don't do it even if it does...
The pressure plate and clutch disc are good cores.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 12-30-2012, 06:48 PM   #5
hamad
hamad's Avatar
WOW a fast response ... thanks guys
so what i understand is that i should swap the flywheel only ?
sounds easy and simple
can i ask from where can i find a 454 flywheel of is there a specific brand i should be looking for ?
Old 12-30-2012, 06:58 PM   #6
geezer#99
geezer#99's Avatar
http://www.summitracing.com/search/p...454%20flywheel
Old 12-30-2012, 06:59 PM   #7
hamad
hamad's Avatar
Originally Posted by geezer#99 View Post
Thanks for the link !
any specific brand you recommend ?
Old 12-30-2012, 07:23 PM   #8
geezer#99
geezer#99's Avatar
ZOOM! Hays!! They're all good.
What year is your 454?
Old 12-30-2012, 07:25 PM   #9
geezer#99
geezer#99's Avatar
You could use just a balance plate with the stock 350 flywheel too! Saves some money.
http://www.summitracing.com/search?k...%20plate&dds=1
Old 12-30-2012, 07:27 PM   #10
hamad
hamad's Avatar
im not sure to be honest but i believe its from the 73-87 body style
Old 12-30-2012, 07:39 PM   #11
geezer#99
geezer#99's Avatar
You better be sure of the year. THe 1987 and up chevy motors used a one piece rear main seal. Flywheel, bellhousing etc where different.
Old 12-30-2012, 07:41 PM   #12
hamad
hamad's Avatar
thanks for the help geezer, i'll be sure to make sure before making any purchases. Thanks again !
Old 12-30-2012, 07:50 PM   #13
geezer#99
geezer#99's Avatar
THe casting number behind the drivers side head will help. Also the numbers off the pad in front of the passenger side head will be needed to tell what you have.
And check the same numbers on the donor truck.
Then look here to decipher it.
http://www.nastyz28.com/decode.php
Old 12-30-2012, 07:57 PM   #14
hamad
hamad's Avatar
will do as soon as possible, thanks man i appreciate it
Old 12-30-2012, 08:58 PM   #15
SSC's76
No No
SSC's76's Avatar
just to put this out there different patter on the flywheel between small and big block. find out what year you engine is and order on for that year. the bbc flywheel from 66 up all use the same patter but different balance I had a heck of a time finding one for my vortec bbc that was the correct balance. if York just using this as a he platform you can get a stock replacement flywheel at any parts store about 80 for a new one
Posted from 67-72chevytrucks.com App for Android
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 12-30-2012, 10:49 PM   #16
INSIDIOUS '86
INSIDIOUS '86's Avatar
454 is an external balance engine. I don't think just throwing a flywheel in ther is going to work out.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 12-30-2012, 11:53 PM   #17
geezer#99
geezer#99's Avatar
Why wouldn't it work out. A dedicated 454 flywheel will be balanced for it. Or a balancer plate with a 350 flywheel that's nuetral balanced.
Easy peasey!!
Old 12-31-2012, 12:25 AM   #18
meatwagon83
meatwagon83's Avatar
all you need to change is the flywheel, from what i understand is, the 350 dont count for diddly squat, he wants t put the stick behind the big block, as far as useing the 350 flywheel, no it wont work, it doesnt matter what year the 350 is
meatwagon83 is offline   Reply With Quote
Old 12-31-2012, 03:16 AM   #19
sethv
sethv's Avatar
Bellhousings are the same. I have a 1 pc rear main engine from an '86 in my '78. Flywheels are definitely different though.
1981 K10 Scottsdale
305 ci | TH350 | NP208 |
60k miles
sethv is offline   Reply With Quote
Old 12-31-2012, 03:18 AM   #20
hamad
hamad's Avatar
thanks everybody, anyone tried this swap and is positively sure ?
Old 12-31-2012, 03:48 AM   #21
bk2life
Originally Posted by hamad View Post
Hello everyone, I found a great donor truck.I It has a SM465 in it, but runs on a 350, and my truck runs on a 454 with a 700R4 tranny.
when are you looking to do this swap? i have the 350 flywheel you need, as my old burban had a 350 with the same trans. what condition is that 700 you have? 2 wd or 4wd?
i ask because id like a 2wd 700 for my truck...
maybe we can parts swap and make up the difference with some cash?
bk2life is offline   Reply With Quote
Old 12-31-2012, 04:03 AM   #22
hamad
hamad's Avatar
To be honest, i'm not quite sure what i want to do this the donor truck yet, it too nice of a truck to throw away for part out, so i thought of using the 700r4 in it for another project, i'll let you know how it goes for sure
About the flywheel, its the 350 flywheel that you have? because from my understanding on the forum members, the 454 flywheel varies from the 350's.
Thanks for the help and i'll get to you as soon as possible about the 700
btw, it a 2wd
Old 12-31-2012, 08:53 AM   #23
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Here is what you need to know....
-Bellhousings are the same. Small block, big block, even six cylinders. The SM465 bellhousing will absolutely bolt directly to your engine.
-454s use a different balance flywheel than small blocks and even other big blocks. You need a standard transmission flywheel for your 454. Bolt it on and go. Folks are muddying the water about the balance issue. Whether you get a used 454 flywheel or a new one, line it up and bolt it on and move on the the next thing. It's that simple.
I say this as the guy who has built two prior big block trucks and now own a current 454 truck with an SM465 in it. It's sitting in my driveway right now. These are things I've learned first hand and done personally.
Tx Firefighter is offline   Reply With Quote
Old 12-31-2012, 11:00 AM   #24
ont_guy_38
ont_guy_38's Avatar
I took a 350 flywheel to a machine shop and had it balanced for a 454, never had a problem with it. That was a lot of years ago though, might not be cost efficient anymore.
1985 C10
2004 Avalanche
ont_guy_38 is offline   Reply With Quote
Old 12-31-2012, 11:08 AM   #25
geezer#99
geezer#99's Avatar
And I too used a 350 flywheel on a 454 using a balance plate and it worked great but then what do I know!!!
