Old 01-01-2013, 07:30 PM   #1
tjmeadows
door swap
Anybody know the difference between the doors on a 69/72? I noticed in my classic industries book that they sell doors 69-71, and 72 differently, just curious if my 69 doors can swap with my 72.
tjmeadows is offline   Reply With Quote
Old 01-01-2013, 07:45 PM   #2
sanford&daughter
sanford&daughter's Avatar
Re: door swap
Iirc they are all interchangeable but the 72 has a few extra hole i think for the vent window
sanford&daughter is offline   Reply With Quote
Old 01-01-2013, 07:45 PM   #3
jocko
jocko's Avatar
Re: door swap
72 has a small screw visible on the inside just below the vent window.
OOPS, sorry - simo post.
Old 01-01-2013, 07:53 PM   #4
tjmeadows
Re: door swap
So I can put my 69 doors on my 72? What is that screw for?
Old 01-01-2013, 07:56 PM   #5
sanford&daughter
Re: door swap
They will fit with no issues i have a 72 door on my 68 and have no problem
Old 01-01-2013, 09:03 PM   #6
Sammy
Re: door swap
Do you have to change the window regulator? I heard the shaft protrudes out further in the 72 doors for the door panel difference. But sure someone will chime in soon. Might also depend on which door panel you use too if using the 68 metal door panel no issue.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 01-01-2013, 09:16 PM   #7
Mustard72
Mustard72's Avatar
Re: door swap
I've got 69 doors on my 72, but the PO is the one that installed them. Doesn't appear to be anything special needed to install them.
Nick
Old Mustard, 1972 Chevy C20, 350, TH350, 4.10 Dana 60 rear, owned since I was 16 in 1986
http://67-72chevytrucks.com/vboard/s...d.php?t=545356
Blue Bell, 1987 K20, 6.2L Diesel, TH400/NP208, 4.10 gears
Ustahav 1976 K10, 350/350/203, Gov Loc, Yooper beater trail truck.
Mustard72 is offline   Reply With Quote
Old 01-01-2013, 09:18 PM   #8
whoryou1979
whoryou1979's Avatar
Re: door swap
Yes, the shafts do stick out further to accommodate for the panels.
All Day Every Day
'72 C20 Cheyenne Custom Camper
http://67-72chevytrucks.com/vboard/s...d.php?t=549132
whoryou1979 is offline   Reply With Quote
Old 01-01-2013, 10:55 PM   #9
tjmeadows
Re: door swap
Thanks everyone
