Old 07-08-2015, 03:32 PM   #1
87Skier
87Skier's Avatar
Wrong master cylinder?
Looking some info...
I thought that these came with either of two or three different brake setups. I thought that they had a smaller diameter thicker booster, a larger diameter thinner booster, and a manual setup. I also thought that dependent on what booster you had is what master cylinder you had.
I have a large diameter thin brake booster, but I believe that I am running the wrong master cylinder. I replaced it about a year ago, when I redid my entire brake system before I started driving it. I bought a new one at a trusted parts store, and it was identical to the one that came off there.
The problem I am having is that the rear brakes feel like they are the only ones working. If I'm on the highway and hit the brakes hard, the rear brakes lockup, the truck gets squirrely (even when the rear don't lockup) and the brake pedal is very hard. I'm 99% sure that I have a drum brake master cylinder and not a front disc master cylinder.
Can anyone confirm this?
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
