Old 01-03-2013, 10:42 AM   #1
UATahoe
87 R10. 383 or built TBI block
Alright, i have decided to retire the stock 350 motor in my 87 R10. I know it at least has 192K miles might even be 292k. First off, i wil be keeping the TBI system and have been working with Brian at Harris Performance on all of the necessary upgrades for that piece. My only dilemma is whether to go with a 383 or a TBI block with Vortec heads. The 383 setup is going to be right at $2900 oil pan to intake. Would be completely ready to go. I have also found an old TBI Block and Vortec heads locally from a family member. Block is completely machined and rebuilt, heads are totally rebuilt as well. All receipts for machine work available and the shops used are really good. Price on that would be $1000 with a lot of extras included that i could probably sell and get some money back on. Only thing needed would be a cam and intake (priced out at $400 total).
So, my questions is, is it worth the extra gains to spend $2900 on the 383 or would it be better to stick with the TBI Block/Vortec HEads combo for $1400?
I have been told the 383 will be around 360hp/420tq and the TBI/Vortec will be around 330hp/380tq.
One other note, i wont do a whole lot of towing and even if i did, it would be with other vehicles. This is mainly just a cruiser that i love to drive.
I am open to any and all comments here. Let me know what you guys think. Thanks!
UATahoe is offline   Reply With Quote
Old 01-03-2013, 10:58 AM   #2
Desert1957
Desert1957's Avatar
Re: 87 R10. 383 or built TBI block
There is nothing better while towing then "TORQUE" the more the better. People get all wrapped up on dyno numbers about "Peak Horsepower" when its a nice smooth torque curve that makes an engine feel strong.
Go with the 383 , might want to re look at the stock style TBI, not sure it will feed a healthy 383 without some modifications.
Desert
Desert1957 is offline   Reply With Quote
Old 01-03-2013, 11:13 AM   #3
UATahoe
I am definitely upgrading the stock TBI with a bored throttle body and better fuel pumps computer upgrade etc. Main reason for the question, i just dont know if its worth the extra $1500 for the 383. At the end of the day, both are basically brand new motors and arent too terribly far apart on performance. Especially considering that both are basically doubling the power output of the stock motor. Both engines will have plenty of power for me.
Old 01-03-2013, 11:27 AM   #4
bk2life
id be leary of this claim
bk2life is offline   Reply With Quote
Old 01-03-2013, 11:31 AM   #5
bnoon
Personally, I'd add a 3rd option. Given the info you have listed, I'd add a Scat crank and KB pistons to the Vortec setup you mentioned and have a 383 Vortec for several hundred less than the other 383 you priced out. As long as Harris Performance has the tricky TBI tuning figured out GO BIGGER! LOL!
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
Old 01-03-2013, 11:43 AM   #6
mooseknuckles
mooseknuckles's Avatar
.....LS swap.
mooseknuckles is offline   Reply With Quote
Old 01-03-2013, 11:53 AM   #7
king-918
king-918's Avatar
383 with vortec heads, and roller block
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 01-03-2013, 11:53 AM   #8
king-918
king-918's Avatar
Oh yeah and carb or true fuel injection
<----Christopher
Oklahoma
Old 01-03-2013, 12:41 PM   #9
UATahoe
To clairfy on those numbers for the TBI, this would be with vortec heads and a Lunati Roller cam. I have all of the parts to convert the TBI block over to a roller setup. Also would utilize a better intake with the bored TBI. It wouldnt just be heads. The 330hp claim doesnt seem too far fetched to me really.
The idea of continuing the build on the TBI/Vortec motor is appealing though and making it into a 383.
Old 01-03-2013, 12:44 PM   #10
Low84
Low84's Avatar
Even though the peak numbers are close to each other it doesn't mean the engines will perform at the near the same level. The 383 should reach it's numbers earlier in the rpm range and they usually have a lot of power under the power band.
I see you saying or the TBI block. Does that mean that the 383 is going to be based off an older 350 block?
I'm very skeptical on that TBI working though, keep us updated. I'd love to see it happen with either option.
1978 stepside C10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=468265
Low84 is offline   Reply With Quote
Old 01-03-2013, 12:47 PM   #11
UATahoe
The 383 is a vortec block and vortec heads.
Old 01-03-2013, 01:10 PM   #12
king-918
king-918's Avatar
Why tbi?
<----Christopher
Oklahoma
Old 01-03-2013, 01:23 PM   #13
UATahoe
Really just for the novelty of keeping it. Only year they offered fuel injection for the squares. Plus, I am not looking to make crazy amounts of power and I have been told I should be fine wih the right upgrades to the fuel system.
Old 01-03-2013, 02:18 PM   #14
school boy
school boy's Avatar
my 86 has a tbi, was it just an option in 86?
school boy is offline   Reply With Quote
Old 01-03-2013, 02:26 PM   #15
Pyrotechnic
Pyrotechnic's Avatar
The TBI will work fine, it's a just a matter of having injectors capable of feeding the engine and being able to tune the computer correctly.
As for the Roller 350 with Vortec heads from the family member, was anything special done to the Vortec heads? Reason I ask is that in stock form they can't handle much of a cam. The valve guides need to be machined down, and it's a good idea to run screw in studs with guide plates. Keep in mind, you will also need run springs that will work with your cam. Don't forget a good set of hardened push rods too that are the correct length. What I'm getting at is that there may be some hidden costs into getting this motor to work for you that you haven't thought of.
If you do decide to build a 383, have it built with a roller cam TBI block. This is what I did and I'm very happy with it, primarily because I don't have to do anything special with the engine oil to get a flat tappet cam to survive. The extra power is nice too.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 01-03-2013, 02:26 PM   #16
Richardman1992
Richardman1992's Avatar
I vote vortec 383 with roller cam and tbi. Have you looked into ebl tuning? From dynamic efi. Doober on fullsize chevy has an ebl tuned vortec 383 with a cam in his 92? I think truck.
2001 Silverado z71 ECSS Cammed, Stalled, headers, BB tuned
1988 Scottsdale 2500 ECLB 4x4- the never starting project
1998 Firebird Formula- stock and slow for now
1987 Iroc LB9/auto/G92- rusty 600 dollar future beater
1991 5.0 Fox Body- 200 dollar running driving project
Richardman1992 is offline   Reply With Quote
Old 01-03-2013, 02:44 PM   #17
UATahoe
Heads are completely reworked with new valves, upgraded valve springs and new pushrods.
I plan on using the upgraded Police car TBI 350 injectors or 454 injectors. One of the two. And i currently have the gm performance parts roller lifter kit to convert the block over to the roller cam.
Old 01-03-2013, 03:09 PM   #18
INSIDIOUS '86
INSIDIOUS '86's Avatar
Tbi was designed for mileage and emissions. Sure you can get it to work but are you prepared to spend half as much on your engine to do it? The vortec 350 is a great engine esp with a roller cam. A 264 comp cam and pocket port heads will do 350 hp easy and be a great everyday. A 383 will tap out vortec heads sooner since it will draw max flow sooner it will be like the 350 but bigger. Bigger power bigger thirst bigger speed an will daily fine. But with stronger heads will be a force of an engine.
If your using the same cam on both the 383 will have barely an advantage
Tbi doesn't like big cams either. It's the number one enemy of tbi
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 01-03-2013, 03:18 PM   #19
UATahoe
Keeping the TBI is definitely costly. about 350 bucks for all the parts (bored tbi, new injectors, tbi adapter) and then of course the computer programming isnt cheap either. I just didnt want to lose the economy of the TBI.
Old 01-03-2013, 03:39 PM   #20
INSIDIOUS '86
Going bigger will always lose economy 1/2lb fuel is one hp per hour.
You may be money ahead doing a mpfi or a tpi
Sounds like a vortec 350 will be a good match. As well as balanced gears and overdrive you should be able to drive it daily and have fun when you want. While not a Prius it won't be a racecar at either
Old 01-03-2013, 03:42 PM   #21
UATahoe
Exactly what i was thinking. AS long as it stays in the 15-20 mpg range i am good. LOL. Hey, good gas mileage is a relative term. And i think the 350 will produce plenty of power, especially over the stock 350. Should be a night and day difference in the two.
Old 01-03-2013, 03:44 PM   #22
UATahoe
What gear ratio would work best? I am not even sure what is in the truck now honestly.
Old 01-04-2013, 02:58 AM   #23
INSIDIOUS '86
Depends if on your trans and where you drive the most city or highway. 3.42 gears are great all around gear 308s seem just a lil to tall geared so I you want a lil more mileage and some performance 3:23 is a great ratio
Old 01-04-2013, 04:14 AM   #24
huahuamick
huahuamick is offline   Reply With Quote
Old 01-04-2013, 08:19 AM   #25
BigBlocksRule
Before you spend the coin having a stock TBI bored and rebuilt, find one off of a 454 and use a simple rebuild kit. You'll need to swap a couple of plug ends (IAC and one other), but you'll have all the airflow you need and bigger injectors for less money.
BigBlocksRule is offline   Reply With Quote
