Old 01-07-2013, 10:19 PM   #1
82ccshorty
82ccshorty's Avatar
Switching crew from 8 to 5
What all is involved in changing a c30 to 5 lug?
1969 chevy camaro Z28 #matchin Factory 4wheel disc
1969 chevy cst10 big block overdrive 5/7 drop dog dishs
1997 gmc yukon 2 door 2 wheel drive project 4/5.5 22s
2004 gmc sierra dually 4/4 lowering daily driver
82ccshorty is offline   Reply With Quote
Old 01-07-2013, 10:20 PM   #2
meatwagon83
meatwagon83's Avatar
Re: Switching crew from 8 to 5
buy a half ton truck
meatwagon83 is offline   Reply With Quote
Old 01-07-2013, 10:24 PM   #3
82ccshorty
82ccshorty's Avatar
I'm going to air ride and tub the rear so I'm going to go 9in rear so it wouldn't be worth buying a parts truck
Old 01-07-2013, 10:26 PM   #4
meatwagon83
if your gonna do that, idk, spindles on out would make sense
Old 01-07-2013, 10:35 PM   #5
KQQL IT
At the body shop.
KQQL IT's Avatar
We just did one. Got 1/2t spindles had them reamed for 3500 ball joints. And changed brake hoses. Theyre different on the caliper side. And a 1/2 rear axle used a spicer cross over U joint. 1350X1310., did it in weekend.
http://67-72chevytrucks.com/vboard/s...d.php?t=552412
Old 01-07-2013, 10:37 PM   #6
comegetsome2003
comegetsome2003's Avatar
Go to the junkyard and pull the upper and lower control arms and 5 lug spindles/hubs/brake calipers and bolt them on ur truck.....i'd prolly grab some new inner and outer tie rod ends from parts store....and most likely balljoints cause its doubtful you will get lucky enough to find one with new/good ones
1991 Square CCLB Dually...laid out on 22s with an old noisy 12 valve
comegetsome2003 is offline   Reply With Quote
Old 01-07-2013, 10:49 PM   #7
82ccshorty
82ccshorty's Avatar
I'm going to be air riding with probably porter built drop member. So I would need drop spindles?
Old 01-07-2013, 10:51 PM   #8
comegetsome2003
If you are goin with a drop member just order new drop spindle....comes with new arms....you will need new rotors/bearings and new calipers/brake lines and you will be set...drop member come with rack so your steering is took care of
Old 01-07-2013, 10:56 PM   #9
82ccshorty
82ccshorty's Avatar
Are racks worth having?
Old 01-07-2013, 10:59 PM   #10
comegetsome2003
Yea rack and pinion steering is gonna be alot tighter
Old 01-07-2013, 11:04 PM   #11
82ccshorty
82ccshorty's Avatar
But the ones I've seen they don't steer is far side to side
Old 01-07-2013, 11:13 PM   #12
82ccshorty
82ccshorty's Avatar
So here's my plan. I want to lay frame on 20s with a 31/18r20 on the back. I know my dads 66 has a maverick 9" under it and it had 29/18r15s on it with just tubs it wasNt laid out though just lowered. If I don't have to use porterbuit to do this that's be great anything to save money is a plus. So what all will I need to do so? And does someone make a 3 or4 link set up for a third member?
Old 01-09-2013, 09:47 AM   #13
82ccshorty
82ccshorty's Avatar
is there a way to make them 5x4.75 bolt pattern?
Old 01-09-2013, 10:50 AM   #14
andrewmp6
If your going to dropmember the front all you need is 1/2 ton spindles and let nate know what your doing so you get the right ball joints.The rear you could probably get away with a weld on rear dropmember ask nate first about your 9 inch.Or a weld in kit from http://www.scottshotrods.com/4link.asp On the bolt pattern take a look at http://www.kplinks.com/product.php?p...&cat=95&page=2
Old 01-09-2013, 10:52 AM   #15
comegetsome2003
Some local guys tell me you can put a s10 hub on a c10 spindle and it will work to swap to smaller lug pattern....never tried it though
Old 01-09-2013, 10:55 AM   #16
82ccshorty
82ccshorty's Avatar
the 9" i have is 5x4.75 the normal truck is 5x5 the wheels i want are 5x4.5 or 5x4.75 only. which is a car pattern. unless someone makes 5x5 wheels that are 20x14or15
