Old 01-28-2013, 09:57 PM   #1
northeimcustom
northeimcustom's Avatar
replacing leaf spring shackle bolts?
I am just installing some drop shackles and I had to cut two bolts off. Stock i am assuming, They appear to be 5 &1/2 inches long 1/2" ish, grade 8. However, the brand new grade 8s I can find locally are 5" (which is fine for length) 1/2" diameter grade 8s. The shaft of the new bolts seem to be smaller in diameter than the ones I cut out. So there is a fuzz of play?
What do I do??
northeimcustom is offline   Reply With Quote
Old 01-28-2013, 10:13 PM   #2
mongoose
mongoose's Avatar
Re: replacing leaf spring shackle bolts?
they're 9/16' bolts.
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 01-28-2013, 10:57 PM   #3
northeimcustom
Thanks!OK great, I guess the hardware store that I was at didn't carry the 9/16" bolts in grade 8. They do have to be grade 8 right??
I know this should be posted in the suspension forum, but the response in that specific forum doesn't yield as many informative responses.
Thanks!
Old 01-28-2013, 11:21 PM   #4
74 stepside
74 stepside's Avatar
Thanks!
Yes, stick with grade 8.
74 stepside is offline   Reply With Quote
Old 01-29-2013, 06:18 AM   #5
donut
donut's Avatar
If your striking out at the local hardware store, try an industrial supply place (like Fastenal). IIRC, that's where I ended up when I did mine.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 02-01-2013, 08:48 AM   #6
Square_78
Square_78's Avatar
Go to your local spring shop or trailer hitch shop and they will have the bolts. I replaced all my leaf spring bolts and got them from the same place that bent me my u-bolts.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 02-01-2013, 09:46 PM   #7
lilpoindexter
lilpoindexter's Avatar
You can also mail order them from McMaster-Carr. I'm lucky enough to live close to one of their warehouses in Santa Fe Springs, CA, so i can order stuff over the phone and pick it up in about an hour.
lilpoindexter is offline   Reply With Quote
