Old 01-19-2013, 08:21 PM   #1
Hazieview
Building Dreams out of Dimes!
You know that little bolt, that holds the 'keeper' rod in your rearend? It's broke...
So I ordered me some of the fancy disk brake brackets. I took off my diff cover and proceeded to take out that little bolt that holds that 'keeper' rod in the rearend.
Well it came out nice and easy but I noticed it was only about 1/4" long.
If this happens to you then you have to be VERY patient! I managed to get that little bolt out. I noticed the rest of the bolt that was broke off had a little barb on it. I got a small allen wrench and put it up against that barb and started bumping that bolt loose a little at a time. You have to be very easy with it. I got my other hand and started wiggling that 'keeper' rod. After a few minutes it backed right out!
1981 Chevy short/wide.
SB400 350th
Hazieview is offline   Reply With Quote
Old 01-19-2013, 08:40 PM   #2
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
Re: You know that little bolt, that holds the 'keeper' rod in your rearend? It's brok
you'd think with all of the goop sloshing around back there the bolt would be nice and lubed up already.
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 01-19-2013, 11:47 PM   #3
Hazieview
You know... That bolt came out with little effort at all. I wonder if a prior owner didn't break that bolt and just leave it in there. That's my best guess,as to why it was broke....
SB400 350th
Old 01-20-2013, 01:22 AM   #4
1984blue6.2
I think it more common for them to be broken than intact lol.
1984 blue and siver GMC K10 lwb - Grandad ordered it new with a 6.2 diesel and a 700r4. now it has a sm465 because teenagers are hard on wore out overdrives with 340,000 miles on them
1984blue6.2 is offline   Reply With Quote
