Old 01-17-2013, 07:20 PM   #1
bsm78
87 Fuel injection issue? With a/c heater fan
Have an 87 with 305. She runs good. Little rough idle, but pretty solid. No speed demon by no means.
Does idle rough and at take off could shut off when the ac or heater is on.
It will bog the engine until rpms get high enough to over come.
I have stepped on it with the fan off and then cut it on during acceleration, felt normal loss in power but nothing like at take off. Could this be a throttle body issue or what do you guys think?
bsm78 is offline   Reply With Quote
Old 01-17-2013, 08:04 PM   #2
motornut
78K & 79C Jimmys
motornut's Avatar
Re: 87 Fuel injection issue? With a/c heater fan
Hi
87 shouldnt it have a solenoid to keep idle up?
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 01-17-2013, 08:19 PM   #3
bsm78
I am a very green shade tree mechanic. Im not sure. I just know its like it starves for gas when ac/heat is on and you have to baby the throttle to keep it from dieing.
Old 01-17-2013, 09:10 PM   #4
pontgta
pontgta's Avatar
Could be the iac....idle adjustment, or fuel related......ses light on?
pontgta is offline   Reply With Quote
Old 01-18-2013, 11:09 PM   #5
bsm78
Havnt noticed any lights.
Old 01-19-2013, 07:53 AM   #6
Vbjunker
Vbjunker's Avatar
IAC
Any idea what the idle rpm is with AC off?
Vbjunker is offline   Reply With Quote
Old 01-19-2013, 12:30 PM   #7
Desert1957
Desert1957's Avatar
TBI or throttle body injection does not have a stepper motor for the throttle.
The ECM automatically adjusted the idle when the A/C or defroster is turned on. If the engine computer is not in "Open Loop" mode meaning all functions are working I don't think the idle function will work as designed.
Is you check engine light on? If so this might be some of the problem.
As mentioned above it never hurts to clean your IAC control once in a while.
Here is a picture of where is gets dirty, Try not to handle or move the plunger while disconnected.
Desert.
Desert1957 is offline   Reply With Quote
