Old 01-09-2013, 10:29 AM   #1
Sundy
Sundy's Avatar
How do I remove the rear brake drum?
The thread search thing isn't working so I'll just ask.
I have brake fluid running down the inside of my driver side rear tire. I tried to remove the drum last night to look at it and...it just won't come off. I took the parking brake off. What else? There's a slot that I'm guessing needs to be liked up with something and then...I do something to the something it's lined up with.
Plese help before I break my brake.
Sundy is offline   Reply With Quote
Old 01-09-2013, 10:47 AM   #2
63chevy4x4
63chevy4x4's Avatar
Re: How do I remove the rear brake drum?
remove the little rubber plug (if its still there) on the bottom of the brake backing plate and back off the self adjuster, you can just use a flat screw driver, there is a special tool for it, if your not sure wich way to turn start turing youll find out haha. then try hitting it from the back side with a dead blow hammer, you might wana hit it with the torch( not litteraly) I have had to have some drums almost red hot in the center to get em off, also use a liberal amount of penetrating oil.
63chevy4x4 is offline   Reply With Quote
Old 01-09-2013, 10:51 AM   #3
WhippinSaw
WhippinSaw's Avatar
You Shouldn't have to but you can try loosening the star adjuster for the brake shoes accessed by removing the grommet on rear of backing plate.
WhippinSaw is offline   Reply With Quote
Old 01-09-2013, 11:14 AM   #4
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
The star wheel mentioned is 5.110 in the picture below. The inspection oval slot is near the 6 o'clock position on the backing plate.
Old 01-09-2013, 12:21 PM   #5
Sundy
Sundy's Avatar
Excellent info, thank you.
Also, I've ordered the 1963 shop manual. I only have the 66 suplimental and it tells me to look in the 63.
Much appreciated!
Old 01-09-2013, 12:56 PM   #6
jayoldschool
Moderator
If you can spin the wheel (in the air/neutral), backing of the star wheel won't do much (unless the shoe has put a groove in the drum). The drum is likely rusted on the axle. You can usually get it off by hitting the face of the drum where it is backed by the axle flange between the lugs. Spray a good penetrant around the axle end where it passes through the drum and keep working it. Sometimes on the really tough ones, you will need to get the torch out to heat the face of the drum to get it to pop off the axle.
Once you replace that leaking cylinder, do a new combi kit and new shoes. Both sides.
jayoldschool is online now   Reply With Quote
Old 01-10-2013, 08:40 PM   #7
Sundy
Sundy's Avatar
OK, I got time to look at this tonight and there is no rubber plug on the backing plate and there is no knockout either. I don't see a way to access the star adjuster. There is a large screw/bolt thing at the top...do I remove that?
Old 01-10-2013, 09:08 PM   #8
earl84
I did mine about 4 weeks ago. Mine had access holes on the drums themselves on the right side drum and on the left side drum it had a stamped area that was just like the access hole on the right side. I knocked that stamped area out with a chisel and gained access to the star wheel. It knocked off pretty easily, actually. Of course, it gets knocked into the drum, but you just pick out the piece once the drum comes off.
The new hardware kit I got had rubber plugs that went into the holes when I put them back together. BTW, I had a heck of a time bleeding the brakes, but that was solved by using a pressure bleeder. It was like magic after fighting it for a long time.
earl84 is offline   Reply With Quote
Old 01-10-2013, 09:12 PM   #9
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
The star access is toward the bottom.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 01-10-2013, 09:14 PM   #10
Sundy
Sundy's Avatar
There's a small thing at about 8:00 in the pic above about the size of the head of a nail. Could the star wheel be behind that? I don't want to break something off that should remain.
Old 01-10-2013, 09:19 PM   #11
earl84
No, that is a guide pin (probably not the correct term) that a spring slides over on the other side. The star wheel is at the 6 oclock position. I did not access mine from the back side, I accessed it through the drum itself.
And it does look a lot like a nail, haha.
Old 01-10-2013, 09:20 PM   #12
LostMy65
LostMy65's Avatar
It's about a 3/4" slot toward the bottom.
Old 01-10-2013, 09:40 PM   #13
jayoldschool
Moderator
You can see the location of the slot for the star wheel in the GM parts diagram above. It's the slot located above part 5.188 "cover".
What I said still applies, though...
Old 01-10-2013, 10:01 PM   #14
Sundy
Sundy's Avatar
GOT IT OFF!!
I guess the penetrating oil I've been spraying this thing with for two days finally worked. I see the star drive thing now, accessible from the front drum slot. I didn't understand what everyone was describing, I thought it was just a bit type you just turned it with a screwdriver. Now I see that I needed to push the teeth from the top or bottom to rotate the shaft of the drive moving the pads in or out. Learned a word.
The white gunk at 9:00 and 3:00 are spider cocoons. This thing is a mess.
Now I need to identify the part I need to order. Thanks for the support!
Old 01-10-2013, 10:05 PM   #15
Hx16457
Hx16457's Avatar
In his defense, I have a 1972 rear end and there are no slots/rubber boots/access holes on mine either.
Spay the drum from the back at the seam where the drum meets the back plate like you are trying to float that thing (WD40), tap (with a BFH) all around the back edge of the drum spraying it all he way around. Get the fluid inside the seam! Let it sit a little while to give the spay a chance.
Get your mind right...." This thing is coming off "!!!!!!!
Git'R done!
People who make excuses didn't want to do it in the first place!
http://s1326.photobucket.com/albums/...cpZZ1QQtppZZ16
Hx16457 is offline   Reply With Quote
Old 01-10-2013, 10:26 PM   #16
Sharps40
Git'R done!
+1 if the drum rotates it's stuck either cause there is a lip the shoes are caught in, star wheel access fixes this....or
Its rusted to the axle and some heat and spray and banging and pryin is called for....(but only after the star wheel is backed off as a just in case measure...never know if the shoes are stuck in a rut in the drum till ya get the drum off)
Sharps40 is offline   Reply With Quote
Old 01-10-2013, 10:27 PM   #17
Sharps40
I did a thread Ol John Lee gets brakes....I photographed every part number used - all came off the shelf from orellies....hang on I'll get ya a link.
Old 01-10-2013, 10:29 PM   #18
Sharps40
Here it is....wheel cylinder part numbers for the 64 C10. Plus a bunca other stuff. Hopefully with some research you'll find some of these parts fit yers if it ain't a 64.
http://67-72chevytrucks.com/vboard/s...d.php?t=558945
Old 01-10-2013, 10:34 PM   #19
Sharps40
Sundy, ya aint far from my mom and dad...they're in centerville. He drives a hopped up orange 47 Chevy truck.
Old 01-10-2013, 10:36 PM   #20
Sharps40
Orellies also carries the wheel cylinder rebuild kits. If yer pistons are tosted just buy the whole cylinder since ya cant get pistons separate.
http://67-72chevytrucks.com/vboard/s...d.php?t=551452
Old 01-10-2013, 10:38 PM   #21
Sundy
Sundy's Avatar
Thanks Sharps, this will help.
Centreville is about 4 miles away which translates to >45 minutes when traffic is on.
Old 01-10-2013, 10:40 PM   #22
Sharps40
Cool. Figured the cylinder hone thread might show better how to pull em out and put em back whether you replace or rehone. As long as yer crackin the back might oughtta pick up hose and hard lines for the rear. If the lines are rusted, ye'll prolly twist em off trying to get em out of the cylinders anyhow.
Old 01-10-2013, 10:41 PM   #23
Sharps40
I know all bout that traffic...its one reason I'm in the sandhill country of NC now. Trees, flowers, smiling faces and no damn traffic.
Old 01-30-2013, 08:27 PM   #24
Sundy
Sundy's Avatar
It's been a while but I found time to change the brake cylinder. But the rods are so rusted and pitted that I don't want to reuse them. LMC doesn't carry them, I called. I can't find them anywhere. Any suggestions?
Old 01-30-2013, 08:39 PM   #25
63burban
Chevy addict
Napa has everything, all the parts for rear brakes are the same for full size passenger cars. 55-about70
63burban is offline   Reply With Quote
