Old 01-06-2012, 11:57 AM   #1
Marshall Truck Fab
C 5000 build
Here it is, finally! A 79 Flatbed that was begging for a remodel! This is right after driving it home, nothing done to it yet.
Marshall Truck Fab is offline   Reply With Quote
Old 01-06-2012, 11:59 AM   #2
Marshall Truck Fab
Re: C 5000 build
Yep, drove it an hour and 15 minutes with that 2year old plate on it without getting stopped!!
Old 01-06-2012, 12:02 PM   #3
Marshall Truck Fab
Re: C 5000 build
First had to take off the bed and see exactly how bad the frame was. Surprisingly good shape, had to fill a few spots from water damage.
Old 01-06-2012, 12:05 PM   #4
Marshall Truck Fab
Re: C 5000 build
Put the plow on it, bed is just sitting there on wood spacers. Frame still original length. Looks great with a plow, but just too tall to avoid little pine trees in driveway!
Old 01-06-2012, 12:07 PM   #5
Marshall Truck Fab
Re: C 5000 build
Thats a small block chevy on the end of the frame rails under the tarp. Needed some weight! Shows the height difference pretty well.
Old 01-06-2012, 12:10 PM   #6
Marshall Truck Fab
Re: C 5000 build
Time to get serious with it and cut the frame. Made up the tools to hold the frame. They are slotted to allow me to slide the halves back together.
Old 01-06-2012, 12:12 PM   #7
Marshall Truck Fab
Re: C 5000 build
Nervous about cutting the frame even though I knew I could do it. So I put the visor on instead!
Old 01-06-2012, 12:16 PM   #8
Marshall Truck Fab
Re: C 5000 build
Frame is cut and truck is back together! You can see the 25" piece I took out on the floor. Had a heck of a time welding it because the frame was magnetic. Nobody can explain that yet. Best I can come up with is maybe it was hit by lightning! went through a lot of gas heating up that much frame!
Old 01-06-2012, 12:18 PM   #9
Marshall Truck Fab
Re: C 5000 build
Bed is on and bed supports made to bolt to original mounting holes. Still aligning everything.
Old 01-06-2012, 12:20 PM   #10
Marshall Truck Fab
Re: C 5000 build
It's together!!!! Time for cosmetics!
Old 01-06-2012, 12:22 PM   #11
Marshall Truck Fab
Re: C 5000 build
Think maybe that was before I finished lining up the bed. It matches the lower skirting on the cab now. And yep, that is a 9' door!
Old 01-06-2012, 12:30 PM   #12
Marshall Truck Fab
Re: C 5000 build
Added the roll-bar and stacks, painted the rims, and sort of hung a bumper from an 88.
Old 01-06-2012, 12:34 PM   #13
Marshall Truck Fab
Re: C 5000 build
Finished washing off debris from body work. Hood and fenders had been abused and repaired once already. Nothing like cleaning up a little rust spot and finding a 4" hole! Had to make a new lower fender, thanks to a friend that has the forming tools and press it went pretty well.
Old 01-06-2012, 12:36 PM   #14
Marshall Truck Fab
Re: C 5000 build
At the local car show, didn't win, but kids had a great time climbing all over it. Wasn't finished anyway.
Old 01-06-2012, 12:39 PM   #15
Marshall Truck Fab
Re: C 5000 build
Bumper is about to get put on right and a plate put behind it to fill the gap.
Old 01-06-2012, 12:40 PM   #16
Marshall Truck Fab
Re: C 5000 build
Had changed the stacks over to the flappers too. I like they way they clang around!
Old 01-06-2012, 12:43 PM   #17
Marshall Truck Fab
Re: C 5000 build
Just think it looks cool with the steam showing up! Still doing odds and ends to it, will post more when I can.
Old 01-06-2012, 12:44 PM   #18
racedaddy
racedaddy's Avatar
Re: C 5000 build
awesome
66 Chevy 305 /350 auto, bagged, custom frame
racedaddy is offline   Reply With Quote
Old 01-06-2012, 01:30 PM   #19
D13
D13's Avatar
Re: C 5000 build
A 5000 long nose!
Want to do that to my 87 C6500 GMC? LOL! First you'd have to get the locked up big block out.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 01-06-2012, 05:10 PM   #20
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Re: C 5000 build
Very smart idea with the slots!!
How is it to drive now vs when it was a longer frame? Is it bouncy?
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 01-07-2012, 10:11 AM   #21
Marshall Truck Fab
Re: C 5000 build
It bounces pretty well!! The flatbed was a lot heavier also. I'm going to do some suspension work to it, but started tearing apart my '70 and got deeper into it than I had planned. After I adjusted the steering slop it is fairly nice to drive, but if you have a bad back you wont make long trips!
Old 01-07-2012, 10:14 AM   #22
Marshall Truck Fab
Re: C 5000 build
Finally got around to putting in the gap cover above and behind the bumper! Vast improvement!
Old 01-07-2012, 10:17 AM   #23
Marshall Truck Fab
Re: C 5000 build
Thanks! it took some thinking but those slots made it so easy to roll the truck back together. all I had to do was lean on the tire and the frame came together exactly where I wanted it.
Old 01-07-2012, 12:23 PM   #24
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: C 5000 build
Reminds me of http://www.bigasstrux.com/
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 01-07-2012, 06:49 PM   #25
lilpoindexter
lilpoindexter's Avatar
Re: C 5000 build
When I lived in Michigan, I hated driving through speed trap infested ohio so much, i would go out of my way to drive through Indiana.
lilpoindexter is offline   Reply With Quote
