Old 02-10-2013, 04:17 PM   #1
yellow400ex05
Thumbs down need a new filler neck gasket like this! help!
where can i find the rubber gasket that goes behind the filler neck on the outside of the truck i found out today that parking on an incline with the drivers side downhill on a full tank it'll run out like crazy.
yellow400ex05 is offline   Reply With Quote
Old 02-10-2013, 06:33 PM   #2
yellow400ex05
Re: need a new filler neck gasket like this! help!
nobody?
Old 02-10-2013, 06:42 PM   #3
Mack B
Mack B's Avatar
Classicparts.com has them, but if I'm reading right, it's your cap that would be leaking?
Mack B is offline   Reply With Quote
Old 02-10-2013, 06:49 PM   #4
TopFuel1966
TopFuel1966's Avatar
Pg. 35
http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=35
TopFuel1966 is offline   Reply With Quote
Old 02-10-2013, 07:21 PM   #5
j.kirn
dont buy the aftermarket 1s they are not made of the same material as original ,they dont last in the sun or if gas gets on them
j.kirn is offline   Reply With Quote
Old 02-10-2013, 07:35 PM   #6
bonehead
bonehead's Avatar
Ditto, Sounds like you need a new cap worst than a seal.
past trucks:
1980 C-10 Silverado SWB
1961 C-10 custom cab LWB
1966 C-10 custom cab LWB
current truck:
1966 C-10 Panel SWB
bonehead is offline   Reply With Quote
Old 02-10-2013, 07:37 PM   #7
71swb4x4
71swb4x4's Avatar
I agree with the others. You need a new cap, that seal does nothing more than keep the weather out of your cab. It has nothing to do with keeping gas in the tank.
If I remember correctly Wes at Classic Parts had some made with a material superior than what others had been selling.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 02-10-2013, 07:38 PM   #8
WhippinSaw
WhippinSaw's Avatar
When I would fill mine up all the way it would also leak. It would happen no matter if the truck was level or not. I thought it might be thermal expansion of the gas as it would happen when it was warmer outside and gas would just push out and start dripping down the side ruining the paint in the sun. I always stopped filling at 3/4 tank. I will have to try a new cap to see if that works. Anyone else with similar experience/?
WhippinSaw is offline   Reply With Quote
Old 02-10-2013, 07:53 PM   #9
63burban
Chevy addict
Is the gas leaking on the inside of the cab or on the outside ? Most times it's the short hose connecting the filler to the tank, they shrink and crack.
63burban is offline   Reply With Quote
Old 02-12-2013, 09:42 PM   #10
71swb4x4
71swb4x4's Avatar
Something is wrong with the venting. I can't tell you exactly what way it is but it may be a vented/non-vented cap issue.
Old 02-12-2013, 09:55 PM   #11
donthekawguy
donthekawguy's Avatar
It's you cap. But a new gasket would look better than the painted one you have on there IMO.
66 shorty
donthekawguy is offline   Reply With Quote
Old 02-13-2013, 08:19 AM   #12
brokenspoke
brokenspoke's Avatar
FYI If memory serves me correct....Lynn Steele has the best quality groment
brokenspoke is offline   Reply With Quote
