Old 02-12-2013, 11:36 PM   #1
70blackfish
can you look at a picture of my Crank?
can you tell from this picture if its a forged or cast crank?
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 02-12-2013, 11:52 PM   #2
JOJABOY
Re: can you look at a picture of my Crank?
And you know I looked.
JOJABOY is offline   Reply With Quote
Old 02-12-2013, 11:58 PM   #3
Mister-B
Lol. Between this thread, and the "how long is your dipstick" thread, who knows what's going on around here
Mister-B is offline   Reply With Quote
Old 02-13-2013, 12:03 AM   #4
JOJABOY
Some folks are just WRONG! ha-ha- What's killing me is the fact that I just had surgery and am pretty much bound to my couch with nothing to do but surf craigslist and read peoples sillyness on here. I did get to peek under hood of a friends truck today. Didn't check out his crank but I did pull his dipstick.
Old 02-13-2013, 12:04 AM   #5
71K20chevy
71K20chevy's Avatar
To me that looks more like a forged one, but I'm no expert
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 02-13-2013, 12:05 AM   #6
Livrat
Member #1049
Livrat's Avatar
Its hard to tell from the angle of your picture,
If the portion I have highlighted shows a "seam" thats approx 1/4" wide its a forged steel crank, if the "Seam" is very thin its a cast crank.
Livrat is offline   Reply With Quote
Old 02-13-2013, 12:20 AM   #7
Mister-B
Lol. I think the meds might be making you slap happy
Old 02-13-2013, 09:56 PM   #8
glider_6969
Since you have the motor this far apart are you able to see any name stamps or numbers anywhere?
68 Long stepper
My other ride ,,, 07 Streetglide..
glider_6969 is offline   Reply With Quote
Old 02-13-2013, 10:35 PM   #9
ItsRandy
ItsRandy's Avatar
I think the question you want to ask would be if your crank is nodular iron or steel. I don't think GM cut any crank shafts from a billet. I am pretty sure most if not all crank shafts are cast from what ever material (nodular iron, steel or some alloy) then forged and/or machined after they are cast. You may be able to buy a crank shaft cut from a billet but it would be way expensive.
If I am wrong someone please let me know.
ItsRandy is offline   Reply With Quote
Old 02-13-2013, 11:05 PM   #10
70blackfish
i know what billet means, and i never asked if it was a billet crank,
Old 02-13-2013, 11:06 PM   #11
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
no
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 02-13-2013, 11:42 PM   #12
jocko
jocko's Avatar
it looks like a cast parting line on the counterweight (i.e. thinner than a forged one) - but like Livrat said, very hard to tell in this pic. If you were to take a pic from the front - showing the part Livrat highlighted, you might get a more definitive answer. Also, pretty sure factory cranks for trucks are cast - is this yoru stock motor out of the 69? Forged was usually high-end stuff for the high-end musclecars, etc.
Old 02-13-2013, 11:51 PM   #13
70blackfish
i bought this motor not knowing much about it. from a friend of a friend. deal...
he didnt know it was a 4 bolt main and also didnt know about the little rust spot. im not if i should just run it this way....
Old 02-13-2013, 11:52 PM   #14
jocko
jocko's Avatar
it looks like it at least needs to be honed, if not bored. Do you have the casting numbers off the rear driver's side of the block?
Old 02-13-2013, 11:54 PM   #15
70blackfish
3970010 casting numbers
Old 02-14-2013, 12:33 AM   #16
bubbaj
Look on the end of the crankshaft where the flywheel mounts if there is a notch cut in the flange it is a steel crank
1970 c-10 lwb named "heavy metal therapy"
bubbaj is offline   Reply With Quote
Old 02-14-2013, 12:39 AM   #17
MusicMan70
MusicMan70's Avatar
Here are the crank numbers from my 70 350 and I believe the cank is crass or the crank is cast steel
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
