Project Heaven in my 67!!!
Short Wide Drops, bring em all...
Ok, trying to get the daughter to pic how she wants her truck to look when the suspension is setup. But, she cant do it without visual aids...
So post them up, calling all pics of your drops, from dramatic to just slight! Please also include how you dropped them, this way when she picks one of your stances I can mirror it with her truck! Please and Thank You! ![]() |
Re: Short Wide Drops, bring em all...
1978 c10. Front: 3in drop springs and 2.5in drop spindles. Rear 3in drop leafs 4in drop shackles and hangers. NO c notch No flip kit. Just cut the bottom outs and mounts off. A lot of miles never bottomed out once. Rides better then stock. Running front shocks on all four corners.
85 C10
Front is 2.5" frame Z 2600 Dom. bags Rear Triangulated 4 link, Step notch, Firestone 9000 Air Springs Dakota Digital leveling controller Photo was taken a standard ride height. ![]()
Roughly 3" and 3" -
![]() ![]() ![]() Cut coils in front, relocated spring hangers in rear. Total cost of drop was about $1.38 for a fist full of grade 8 bolts (plus an alignment). Tires are P235/75R15. Been a daily driver for 27 years; 200,000 miles with no issues. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Frequent Flyer
Roughly 6/8 drop using all Western Chassis Parts.
#6 | |
#7 | |
Relocated Spring hangers in the rear??? Can you give a little more on how you did this as well? Im thinking if she wants to run 20" rims this might be the height it needs to be... |
Cruzzzn' Vet
4/5 drop, 2 cut coils on the front and flip kit on the rear.
![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us |
![]() Join Date: Sep 2010
Mcgaughys 2.5 drop spindles, mcgaughys 1" springs and mcgaughy flip kit with KYB stock length shocks and shock extenders in the rear with NO notch.
Posted via Mobile Device |
![]() 3/5 belltech spindles, and AOL in the rear
Tyler ------------------------------------------------------ 1980 2wd blazer 1985 k10 diesel truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=652276 1987 wrangler 4x4 build-http://67-72chevytrucks.com/vboard/s...d.php?t=663784 |
It is the standard drop hangers and shackles. Then I added 3in drop leafs. when I was done is was sitting hard on the bottom outs. I took those out now i HAVE 4 1/2IN axel travel. Bolted my buddy's 20's on it just for fun. It looked SICK. Just don't have cash for new wheels right now.
#14 | |
And about what was the total cost on your drop if you don't mind me asking? Been getting ready to drop mine, but blowin my motor set my timeframe back a little, so I have a little more time to plan the drop now.
86 Short Bed Build I don't always downshift when I want to change lanes... But when I do, I make sure it's next to a prius so they know I'm hurting the environment! |
#15 |
been here longer than Liz
Most photo hosting sites here at work are blocked. Few I can access are a PITA.
My 87 (sig pic) is about 6/8. Trying from memory here, I did the final drop back in '96. 4" spindles & 2" springs up front Flip kit & 2" hangars in the back Can't remember where I got them.
~Greg~ Mac's Garage '87 SWB 6/8 drop "Piso" '08 CCSB Silverado DD the departed '89 GMC K5 Jimmy 4x4 "Rusty Nuts" '77 Chevy K5 Blazer 2wd '83 Chevy stepside "You get what you pay for" - Mike 'swervin ervin' Ervin |
#16 |
Diggin The SquareLife
5/6 2.5" springs, 2.5" spindles and 6" flip kit
#17 |
#18 |
Porterbuilt.........
#19 |
Very nice color, drop & rims.
Rincon |
#20 |
Spear and magic helmet!
My lowering kit was 2.5" spindles and 2" springs front and a flip kit for the rear. Everything's from McGaughy's. Here's a link to the kit:
http://www.mcgaughystore.com/mcgaugh...it-part-93150/ The front dropped a bit more than advertised, but the fender bottom just covers the tires, which is where I wanted it. I also had to swap the rear leafs side to side because the standard issue square body gas tank lean was very pronounced at this height. ![]() ![]() ![]() |
#21 |
6-8 drop
![]() ![]() ![]() Red trucks rule! ![]() Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
#22 | |
1974 C10 swb 350 1977 3/4 ton Silverado 454 1999 2 door 2wd Tahoe |
#23 | ||
![]() Moving the bottom bolt of the rear hanger into the top bolt of the rail results in 3". I also run the shackle eye bolt through the rail, using a spacer, ending up with 3 attachments (two grade 8 bolts plus the shackle bolt). ![]() Shackle eye bolt running through frame rail, with spacer: ![]()
#24 |
John 82 Chevy Silverado 350ci/TH350 ![]() |
#25 |
That's the exact stance and kit I want to use. How was it to install? Any problems/issues?
RIZ |
