Old 02-02-2013, 07:07 PM   #1
Codez67Chevy
Codez67Chevy's Avatar
Question D-Max in the 67
So a future plan....... my truck is a 3/4 ton. I wanna put a Duramax in it. I'm guessing I'm going to have to box my frame but now the question is will the front suspension hold the weight of the motor? Anyone with out there that has done the same? Would I have to up grade my suspension to a 1 ton? Anything helps thanks.
" Dead Pumpkin" 67 Chevy short bed, 292 I6, 4spd manual. Fan of the "Slant Noses".
93' Toyota pickup 2WD 2dr and 32mpg. Daily driver. 300k+
Members I've met...
Mister-B
Codez67Chevy is offline   Reply With Quote
Old 02-02-2013, 07:21 PM   #2
ryanroo
ryanroo's Avatar
Re: D-Max in the 67
4x4 or 4x2? in my 4x4 the 4" front springs settled very little under the weight of a p-pump 12v and 47re. that combo is north of 1300# if i recall correctly.
leafs are different than coils though, so if its a 4x2 i imagine you may need a spring with a heavier rate. a dmax is somewhere around 840# by itself and the trans will tack another 350+/- that is probably close to 5-600# more than the stock stuff depending on the engine you had.
72duraburb has a dmax swapped 2wd burb and may be able to give you some ideas. i am not sure of anyone that has done a dmax in a 4x4
http://67-72chevytrucks.com/vboard/s...d.php?t=472138
ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 02-03-2013, 09:36 AM   #3
502ms
502ms's Avatar
Re: D-Max in the 67
I had a 1200lb Cummins 6bt in my c10. It will definitely compress stock springs a bit. But not enough to freak out. Bags would be a great idea, along with the boxing.
http://leonmillette.photoshelter.com...000M3o93Yy0iCw
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 02-04-2013, 02:34 AM   #4
andrewmp6
Re: D-Max in the 67
A cummins would be a easier swap if you get a 12 valve.If your worried about weight a 4bt cummins weights 750lbs but its a 4 cylinder version of the 12 valve 5.9.
Old 02-04-2013, 10:05 AM   #5
Codez67Chevy
Re: D-Max in the 67
I'm a Cummins guy myself and it would be easier to put in, but I like being different and since it's a Chevy why not put a Duramax in it.
Members I've met...
Mister-B
Old 02-25-2013, 10:00 PM   #6
tk-mpl
tk-mpl's Avatar
Re: D-Max in the 67
Pacific Performance Engineering built a pretty sweet one.
1968 short box stepside.
2007 5.3L 4L60, tuned w/EFI Live
2005 Silverado bucket seats.
Dominator 2600's all around.
Porterbuilt tubular control arms.
Magnaflow 3" dual exhaust.
tk-mpl is offline   Reply With Quote
