Old 03-10-2013, 07:59 AM   #1
KyFarm
KyFarm's Avatar
Inside door seal channel
Ok, I took off the drivers side inside door panel on my truck, it has doors from a '72, to replace some parts inside the door and line with sound deadener. The LMC book shows a foam seal (2 sided foam sticky tape) that goes on the door between the door and the panel.
There was not a foam seal when I took off the panel, but there was a plastic bag sheet glued more to the inside of that channel.
Does the foam seal go in this channel? Thanks for any help.
KyFarm's Build/Need help thread
1969 K-10, Short Step, (383HT/4L70E soon)-NP205
KyFarm is offline   Reply With Quote
