67 C-10 5.3 swap questions
This is my first post, so go easy on me. I'm in the process of restoring the 67 c-10 longbed stepside my late grandpa bought new. Decided to do a 5.3 LS/ TH400 swap to make it a little more fun to drive than the original 250 / 3 speed. Here is the question....is there a set of mounts available to bolt the 5.3 up to my 6 cylinder frame towers? Thanks in advance.
Jason |
Re: 67 C-10 5.3 swap questions
Not a 100% but I think if you search "Dirty Dingo" is a company out of AZ that makes those.
Check this section out, there is a FAQ section that may have your answer. I think being a 2wheel drive makes it easier. Maybe ask a moderator to move your post there and it might get more traffic.
http://67-72chevytrucks.com/vboard/f...play.php?f=206 |
the boat guy
Speed and performance makes adapter plates as well as many other places, you can also find templates to make the mounts yourself.
Check out the section of the forum dedicated to LSx swaps in the engine and drivetrain section of the forum. Posted via Mobile Device
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
![]() Join Date: Apr 2010
I used the dirty dingo mounts and adapters. the motor bolted right to the 6 cylinder towers with what I feel is good clearance.
No need for my input cause this one was answered QUICK
72 Chevy LB, LS in the works, 4L80, Grandfather bought it brand new. 66 GMC Short Step, 84 Front Suspension, many more mods to come 67 Chevy 3/4 Ton, 327, Auto, Factory A/C Ya must have been movin cause I was haulin a*$ when I passed you |
Just curious why you would do a TH400 with a 5.3? If you have the computer, you may as well put a 4L60E and get the benefits of overdrive.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
might i suggest you join us over at the LSx swap section. if you go to the home page go to engine and drivetrain section then there is a huge sub forum for LSx swaps
70 C10 working on a LSx swap ![]() 4.8L MS3 edelbrock pro flo intake, pacesetter long tubes, 4l60e 2500 stall hoping the tranny holds up lol |
Thanks for the info everybody.
chasinhiway, can you give me the particulars on what you ordered from dirty dingo? There are a ton of choices there and I'm not sure what to pick. MARKDTN, I'm doing a carb swap on the 5.3 so thats the reason for using the turbo 400. I'm a lot more comfortable with a carb and think it fits in a little better with the old truck. Jason |
These are the adapters I used:
http://dirtydingo.com/store/index.ph...=1_206_305_335 They also sell the engine mount itself that I bought. The passenger side rubber mount has to be trimmed at the bottom and theirs comes trimmed. I called them and told them what I was doing and they told me what would work. |
#11 | |
Vintage 4x4s
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ![]() 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
I will probably be flamed, but to me there is absolutely no reason to carburate an LS. They are made to be fuel injected. It will not cost any more to inject it than carb it and you will be SO FAR ahead in reliability and mileage. Flame away, but that is my .02
