Fuel problem with a ls swap please help
Im having a issue with keeping fuel at the rail, im using a fuel cell thats vented, aeromotive regulator, walbro pump, the pump turn on everytime I turn the key but I have floor the gas pedal for it to start up other wise the engine wont fire up is has a ls1 intake with the built in regulator on it, is it possible that the regulator on the on the intake has gone bad and doesnt hold fuel pressure?
Posted via Mobile Device |
Re: Fuel problem with a ls swap please help
You have a 97-98 Corvette fuel rail with both feed and return lines? That's the only LS1 fuel rail that has a built in regulator. Camaros with returnless rails dont have a regulator, just a pulsator. Have you verified that it isn't holding pressure with a gauge? Usually having to floor the pedal to get it to start means you're getting too much fuel and flooring it puts it in clear flood mode.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
I have the Ls1 intake that came from a camaro, which only has a feed my return is at the regulator
Is t possible that its doing ths because the o2 sensors are not installed yet in the exhaust , the fuel regulator is brand new and set at 60psi
#6 | |
Even though you have a new fuel reg. you REALLY need to check your fuel pressure at the RAIL. How are you determining fuel pressure? Your prob. gonna find you do not have enough pressure. I know your saying the regulator is new BUT ......I had both o2 sensors that had a problem right out of the box! I bought Denso brand o2 sensors and my CEL hasnt come on since. Just because it's new doesnt mean its good. |
