Old 04-03-2013, 07:27 PM   #1
Steve-W
Steve-W's Avatar
Dutch guy has problems with brake lines
Because US sizes are considered odd in Europe, 1/4" brake lines are not common, usualy everything is 3/16". what is the real problem when using only 3/16" tubing all around?
Feedback is always welcome!
projects:
1969 Chevy C10
1950 GMC 100
1958 Chevy C60 Viking ratrod
Steve-W is offline   Reply With Quote
Old 04-04-2013, 12:39 AM   #2
oldspowered67C10
Re: Dutch guy has problems with brake lines
As far as i know there is no problem, I used 3/16 all the way around(4 wheel disc) and have no problems.
oldspowered67C10 is offline   Reply With Quote
Old 04-04-2013, 04:42 PM   #3
Steve-W
Steve-W's Avatar
thats my thought exactly, but in the manual it mentions 1/4" tubing going to the back en 3/16" to the front and I wonder why.
I mean force = pressure x surface space..so the diameter of the tubing should be an issue right? or has it to do with the response time after applying the brake?
projects:
1969 Chevy C10
1950 GMC 100
Old 04-07-2013, 08:03 AM   #4
wraprail
wraprail's Avatar
Use 3/16 everywhere. Everyone does be it street car, race car or cable car. 3/16 steel brake line is the ticket. :0
wraprail is offline   Reply With Quote
Old 04-08-2013, 05:45 PM   #5
Steve-W
Steve-W's Avatar
Ok, so the diameter of the brake line doesn't matter.
Another question:
will the original brake proportion valve work now I have converted the front to disks? I always thought the split was about 60% front 40% rear?
is there a difference between all drum brakes (without a booster) and a disk front/drum rear (with a booster) setup?
projects:
1969 Chevy C10
1950 GMC 100
