Front a-arm abnormality
so I had originally thought my frame was bent, or twisted somehow. largely based on a uneven stance and then I found shims mounting the upper A arm to the frame. they were to extend the A arm about 1/2 inch. however today I changed out the radiator support, inner fenders, and passenger fender. every part went on smooth and with even lines. I've never had one go together so easy before. I used the orig grill. in my experience if the frame is bent, this easy assembly would be very difficult. so my question is:
Why would someone shim the A arm? I got the truck with its orig 140,000 miles. it's a inline 6 and had some damage to the front pass fender and bumper same side. all the damage is long on the fender. no damage above the bottom of the grill. on a side note, I love finding the stupid half a$$ fixes my the inept prev owner. if you can fix cars or learn to do it right, don't do it. |
Re: Front a-arm abnormality
vehicles get shimmed from the factory for alignment. Even though your frame is straight...part manufacturing isnt a 100% accuracy procedure. Mine had 3 shims on it from factory and after lowering it it got a few more.
I guess I should have used the words large washers. but I'm guessing they were added as shims but the prev owner.
Washers are good practice in place of several shims so they cannot fall out. The drill is to set up the alignmet with a shim pack then replace them with matching washers.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
