Old 03-10-2013, 05:15 PM   #1
jorgensensc
jorgensensc's Avatar
Final verdict on electric fans?
Hey all,
I have read all the different threads I have found on electric fans with stock 4 core radiators. I've seen to use the Taurus fans, maxima fans,windstar fans, jeep Cherokee fan, even the HHR fan. My question is this: which one of these has actually been used successfully for any length of time. This will be used with a 6.2 ls motor, so not sure if it needs more cooling or not. I have the stock dual electric fans from the donor vehicle, but it will take some work to make it fit. I'm looking for easier but not crazy expensive. Also, can I go with new aftermarket fans? Are they reliable? They are only about 80.00 on eBay for dorman fans. Thanks for the input all!
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
