JT's and other weight distribution
Hello all I am thinking about the weight of these old trucks. I drive mine so it has some of the nice things so I know it will be heavier than others. This includes a heavy rear cover and AC...
I was reading in the handling thread and Rob mentioned in September of 2012 JT had a total weight of 3850 with a rear weight of 1400 pounds. That puts the rear at 36%, probably normal for a truck. then in January of 2013 it had a weight balance of 57% front and 43% rear. The new weight was not mentioned but wanted to pick Rob's brain on this as that is a big weight shift and or loss. What has everybody else done? And where do you weigh. Mine seems heavy but like I said my cover is a couple hundred pounds but looks and functions great. I know my wheels and tires are heavy too. Mine is 4250 total with 1750 over the rear. That is with me plus a few things inside. That is right at 41% rear. My 5.3 is mounted on custom mounts to get it as far back and down as possible. It was basically built in place... Thanks all Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
