Old 04-27-2013, 04:36 PM   #1
davecarney2
davecarney2's Avatar
performance suggestions
I have a 2003 6.0 out of a 2003 SS Silverado and a 4L80E trans. Any performance suggestions I should do prior to installing it. The engine has 80K on it and the trans has 107K on it. Think I should have em freshened up a little prior to install or just get it on the road for now? I know I wont be the fastest so not worried about big HP #'s jsut would like a good sounding engine with 350-400hp in my 59' This engine is supposed to be 345 so the hp isnt bad just not sure if I should put a thumper cam or something in it. Any suggestions would be appreciated.
davecarney2 is offline   Reply With Quote
Old 04-27-2013, 06:28 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: performance suggestions
4l80e's are pretty stout, and unless there is some obvious mechanical defect, I'd leave it alone for a "driver". Might not be a bad idea to get a better stall convertor (suited to your needs and the cam you choose) just to get a little more performance out of whats there.
With 80k on the engine (again assuming there are no obvious mechanical problems), I'd just put a new oil pump and timing chain kit on it, do whatever cam you wanted, and you'll need a new set of exhaust manifolds since the truck manifolds don't fit between the rails and motor mounts on these older trucks. That will be enough to get you on the road safely and pretty reliably.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-27-2013, 09:58 PM   #3
Custom 68
Custom 68's Avatar
These motors like a cam change. Get that and a good tune and you will be set.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 04-27-2013, 10:07 PM   #4
davecarney2
Any idea what they did different to get the 50 extra hp for the trailblazer SS v/s the Silverado SS???
Old 04-27-2013, 10:42 PM   #5
Super73
Super73's Avatar
Yes, they use an LS2 block which has a bit more compression paired with LS6 heads and LS6 cam. Not to mention a better intake and throttle body.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 04-28-2013, 09:59 AM   #6
1969x11
Mid 220 to 230 duration cam, valve springs matched for cam lift , hardned pushrods. Circle-d budget 278mm 4l80e converter.Should get you around 375rwhp with a good tune.
1969x11 is offline   Reply With Quote
Old 04-28-2013, 11:03 AM   #7
truckdude239
truckdude239's Avatar
MKe sure you have the torque management turned off in the computer
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 04-29-2013, 07:45 AM   #8
davecarney2
thanks guys
Old 04-29-2013, 11:19 AM   #9
Wasted Income
Boosted Member
Wasted Income's Avatar
Lots of good info from the guys in this thread.
I built this car for my brother last year.
LQ4 / 4L80E
228/230, .571"/.573" - 112 LSA
317 Heads
LS6 Intake
Longtubes with dual 3"
Revmax 9.5" 3400 stall, 3.42 rear gear
EFI Live Speed Density tune by me
150 shot of spray
536 to the wheels.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
