Old 04-30-2013, 12:32 PM   #1
54blackhornet
54blackhornet's Avatar
The Carb Shop ?
Thinking about sending my QJet #7041211 to the Carb Shop in Calf, had it rebuilt by a local "expert" but it still floods over on to manifold almost every time I try to start it? Also when it does start ,it has a bad miss at all speeds from idle on up ? Any feed back on their QJet over haul work would be great. Thanks
71 C-20
07 Magnum RT AWD
54blackhornet is online now   Reply With Quote
Old 04-30-2013, 12:36 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: The Carb Shop ?
Sounds like all it needs are the floats adjusted correctly. If the floats are screwed up and let too much fuel in... you will get fuel leaks on the manifold. That's probably your miss too... it will run pretty fat. Any fouled plugs?
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 04-30-2013, 12:54 PM   #3
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Re: The Carb Shop ?
These guys are the premiere shop in the country for quadrajets. It will come back better than it ever was from the factory. You will love it. I've had several carbs done there.
Tom Vogel is offline   Reply With Quote
Old 04-30-2013, 01:06 PM   #4
Rufton
Re: The Carb Shop ?
Gary
Yeap.
I'd also make sure the float floats (not leaking).
Make sure the inlet fuel shut off valve actuated by float is clean and seating.
Rufton is offline   Reply With Quote
Old 04-30-2013, 02:18 PM   #5
54blackhornet
Re: The Carb Shop ?
thanks guys ! I am tired of taking it on and off again, figured it was time to let a person do it who see's and works on them all week long , not once and while ? I will do a follow up when I get it back.
71 C-20
07 Magnum RT AWD
Old 04-30-2013, 02:30 PM   #6
C0UCH
Re: The Carb Shop ?
Anyone know off hand if they accept complete vehicles? The Carb Shop is on my way home from work and its been running a bit odd lately. I replaced the carb to keep it on the road and that fixed many of my issues but it still feels like it needs carb work.
C0UCH is offline   Reply With Quote
Old 04-30-2013, 03:38 PM   #7
GASoline71
GASoline71's Avatar
Re: The Carb Shop ?
Stop in and check?
Gary
Old 04-30-2013, 04:01 PM   #8
Wrenchbender Ret
Re: The Carb Shop ?
Regardless how good the rebuilder is, if you get dirt in the needle & seat its going to flood over.
Wrenchbender Ret is offline   Reply With Quote
Old 04-30-2013, 04:29 PM   #9
MARKDTN
Re: The Carb Shop ?
They used to be great. A year or so ago I had heard that the owner died and the son was not so good. Hope that has changed. I had one done 15 years ago and it was outstanding.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 04-30-2013, 04:36 PM   #10
vectorit
What?
vectorit's Avatar
Re: The Carb Shop ?
I am running one of their Q-jet carbs right now on my burb.
It ran great for close to 15 years, but this last weekend it just now started having issues.
I am thinking about going to SMI for it's replacement?
http://www.smicarburetor.com/product...2/productID/18
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
