Old 04-07-2013, 11:40 PM   #1
BlackedOut67shorty
BlackedOut67shorty's Avatar
4x4 conversion ?s
I've looked but I haven't seen if anyone ever kept trailing arms when they converted their 2 wheel drive to 4 wheel drive.
1995 s10 blazer 4.3
1967 c10 350/350 fleet short
1993 s10 blazer 4.3l 4l60 RIP 6/20/14
2000 mercury sable
Thats a how I roll
BlackedOut67shorty is offline   Reply With Quote
Old 04-08-2013, 11:27 AM   #2
BlackedOut67shorty
Re: 4x4 conversion ?s
I wasn't looking into lifting it, just keeping it at stockish height but I'm not sure if it can he done since I think the crossmembers are pushed back from the transfer case?
1995 s10 blazer 4.3
2000 mercury sable
Thats a how I roll
Old 04-08-2013, 08:45 PM   #3
RANDY COX
RANDY COX's Avatar
I think I remember yrs ago seeing a truck fixed up like that,2wd to 4wd,with the rear trailing arms...maybe someone else will chime in...
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 04-09-2013, 12:18 AM   #4
argonaut
argonaut's Avatar
I've seen one done that way also. A 72 with a Dana 44 up front and and trailing arms in back. If I remember correctly the owner had mounted the axle beneath the arms rather than on top to gain lift without having a steep angle to the arms.
Personally I think it would be cool to mount the front on radius arms and a track bar with coil springs to match the back.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 04-09-2013, 12:26 AM   #5
BlackedOut67shorty
Thanks for the responses guys, now for the front end would I just be able to swap in a 73 and up straight axle with the leaf spring or would I have to try and find period correct parts to keep it simpler. Sorry for some dumb questions since I'm kinda new at doing a conversion like this..
1995 s10 blazer 4.3
2000 mercury sable
Thats a how I roll
Old 04-09-2013, 10:38 PM   #6
wyomech
wyomech's Avatar
I am using trailing arms on my 63 conversion, it is in the 4x4 build section,but I havent posted pics yet of the rear axle I mounted it under the arms
wyomech is offline   Reply With Quote
Old 04-10-2013, 06:48 PM   #7
obijuan
heres a pic i saved on the fly. super easy to do.
obijuan is offline   Reply With Quote
Old 04-18-2013, 09:09 PM   #8
burton'sblazer
burton'sblazer's Avatar
I did the same conversion years ago. I found a blazer frame with all of the front spring hangers. Cut them off the 4wd frame and swapped them out onto the 2wd frame. The core support mounts will bolt straight in. The rear mounts will require some careful measuring to place inside of the frame rails. Be sure to find a 4wd engine cross member to tie your frame rails together. I thought the swap was easy, but the rear end always felt soft compared to the front. Anyway, 6 months after all my hard work, a guy pulled out in front me in Athens, GA a took the front end off of the truck. Just my luck. LOL
burton'sblazer is offline   Reply With Quote
Old 04-18-2013, 10:16 PM   #9
monte0185
monte0185's Avatar
I could be wrong but didn't some of the 4wd's come with trailing arms from the factory?? Think ive seen one or two over the years that were like that.
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 04-25-2013, 11:51 AM   #10
BlackedOut67shorty
Thank you guys and thanks obijuan for the pics. Now for the front I assume I would have to find a 71 to 72 front axle and get the springs and whatnot from the same said years. I want to try and get the disc brakes from the get go so its the reason I say 71 to 72. It be nice to be able to use springs and suspension parts from later years but I dont think they would work with the 67 frame. But someone please correct me if I'm wrong
1995 s10 blazer 4.3
2000 mercury sable
Thats a how I roll
Old 04-25-2013, 01:44 PM   #11
obijuan
If you can measure your widest point of your front frame horns I can measure the widest point of my 85 frame. I can't imagine why later brackets won't fit.
Old 04-25-2013, 02:56 PM   #12
pinefieldfarm
pinefieldfarm's Avatar
I've been thinking about converting my '61 C25 to 4x4 after seeing this nice conversion on a '65 truck. This guy didn't flip the rear axle under the trailing arms, but had a newer Dana 44 with disc brakes up front on it. It sat at a good height and looked to work fairly well. Thanks for asking the questions I've been trying to get answers to.
pinefieldfarm is offline   Reply With Quote
Old 04-25-2013, 03:04 PM   #13
pinefieldfarm
Here's that '65 conversion. This is what it would look like without any lift.
Old 04-25-2013, 07:37 PM   #14
BlackedOut67shorty
I didn't think you.could mount leafs upside down like that, I'm gonna measure my frame up to see the width
1995 s10 blazer 4.3
2000 mercury sable
Thats a how I roll
Old 04-25-2013, 09:52 PM   #15
beardface
beardface's Avatar
Hahahaha.
Those front leaves arn't upsidedown. They are just stock leaves, they have negative arch like than. Granted those look like they have sagged a bit more than usual, but thats 'normal'.
Leon
'68 K20 fleetside, 400sb/sm465/np205, 4" lift, 32" tires.
beardface is offline   Reply With Quote
Old 05-03-2013, 08:18 PM   #16
BlackedOut67shorty
My frame width is 28 inches and 1/8th of an inch from the edges of the framerails
1995 s10 blazer 4.3
2000 mercury sable
Thats a how I roll
Old 05-27-2013, 10:39 PM   #17
mknittle
mknittle's Avatar
There are quite a few guys that did the front axle conversion in the 4X4 section. And the idea of the rear seems like it would work well
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
