Factory GM Serpentine Setup Help
Gents,
I mounted a serpentine set up with AC delete to my '65. I'm a little lost as to what upper hose to use. The factory 65 hose interferes with the alternator. I'm running the stock HD radiator with 1.75" inlet/outlet. I'm hoping to not have to use a flexy hose! Any help? Posted via Mobile Device
1965 Chevy Short Box Stepside, 230 - 3 speed, 4:11 gears, original paint rust free survivor. Now sporting a 383 SBC and TKO-600 |
Re: Factory GM Serpentine Setup Help
I am running the GM serpentine setup as well. It is a great system! Very well engineered and light-years ahead of the old V-belt systems. I really like it. I too had interference issues with the upper rad. hose. What I did was go down to the parts store and dig through the various hoses they have hanging on the racks. I found one that was the right diameter and had bends that seemed like would fit. Bought it, lined it up, cut it, and bolted it right in.
Don't suppose you have the number off it? Nobody has much stock of anything here.
![]() Join Date: Mar 2005
I'm all ears on this one. I'm using a serpentine system from a 1990 half-ton truck. I was planning on bending up a tube like the V-8 trucks had and using the small 4" hose sections on each end.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
One foot in front of the other
![]() Join Date: Aug 2008
Thought about going to your local muffler shop and having them bend you a piece of alumanized exhaust material?
![]() Join Date: Sep 2006
This is what I did. It is a BB but pretty much the same. I had to get a thermostat housing from a van which pointed straight up and I also needed it to be threaded so I could put a return line for the heater on it.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
What I did on mine is I went to the local parts store and went through all the (gates) flex hoses and found the correct length (upper and lower hoses)...sorry cant find the part #s... I ordered a chevy 45 degree rotating water neck thermostat housing swivel style on ebay (Whites Performance) with shipping under $15.00..here sum pics...
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
all, how did you run the alternator wiring with this setup? i currently have the old alternator running the one wire setup, any help would be grateful
#9 | |
please post part# if you have them---
1961 chevy K10 my build is------------61K10 build |
Moderator
![]() Join Date: Dec 2012
The stat housing from the 91-93 Roadmaster/Caprice might help. It points backwards to clear the hose around the accessories.
#12 | |
Thanks doobiebro
