Old 05-28-2013, 05:38 PM   #1
Vernski
Door weather strip
I am posting 2 pictures of door weather stripping so you can see what you get with cheap stuff. In both pics the taller or bigger piece of strip is made across the Pacific ocean. The smaller piece is made here in the good old USA by Steel rubber products. http://www.steelerubber.com/ It does cost more money for it but it will fit the truck and you can close your door. It is well worth the extra $$ just be sure and check the point of origin, they don't have a clue how to make one over there.
Vernski is offline   Reply With Quote
Old 05-28-2013, 06:49 PM   #2
RANDY COX
RANDY COX's Avatar
Re: Door weather strip
Thanks Vernski for the info.Everything that comes across the waters is always off....hard to beat MADE IN USA...
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 05-28-2013, 06:54 PM   #3
corvettejim1968
corvettejim1968's Avatar
thanks for the link. im sure i will use it someday
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline   Reply With Quote
Old 05-29-2013, 07:42 AM   #4
K98AL
K98AL's Avatar
Thank YOU!
K98AL is offline   Reply With Quote
Old 05-29-2013, 09:06 AM   #5
jbgroby
jbgroby's Avatar
Thank you on the infor. will do.
jbgroby is offline   Reply With Quote
Old 05-29-2013, 09:48 AM   #6
JMR5
JMR5's Avatar
I just installed door seals on my 60 GMC yesterday and the doors don't want to close....the weatherstripping came with the truck from the prior owner so I'm guessing I may have the crappy stuff!
JMR5 is offline   Reply With Quote
Old 05-29-2013, 10:29 AM   #7
hd74
I put weather strip on my doors 2 years ago and the still do not shut good I think I put the bigger one on.
hd74 is offline   Reply With Quote
Old 05-29-2013, 11:00 AM   #8
newbe351
Is there a good product to get the black adhesive off without ruining your paint? I had my painter install the cheap door seals that I bought several years ago (waiting for paint), and now my doors won't close. The adhesive that came with the seals was dried out, so he bought some unknown black adhesive at the local auto parts store. The guy should stick to paint and not installing seals because he got the glue everywhere. I would like to remove and replace with the Steel product, but it is a mess under (and in some cases, beyond) the current seals.
newbe351 is offline   Reply With Quote
Old 05-29-2013, 11:43 AM   #9
rideblue00
rideblue00's Avatar
this is good info, thanks. im not far off from installing mine and now i will be getting the steele stuff.
rideblue00 is offline   Reply With Quote
Old 05-29-2013, 01:02 PM   #10
FetchMeAPepsi
FetchMeAPepsi's Avatar
You might try "Goo Gone" its a bug and tar remover that works well with trim adhesive. Safe for paint too.
Step by steps:
Remove primer to reveal original paint
Rebuild a carburetor
See My Build - Cecilia!
Some people are like slinkys. Not worth much but funny as heck when pushed down stairs.
FetchMeAPepsi is offline   Reply With Quote
Old 05-29-2013, 01:27 PM   #11
Vernski
I used the clear 3-M that Steel recommended you can clean it up with mineral spirits. I don't know about what ever the black stuff is. You will have to find out what the black stuff was as the clean up may be different. Even the 3-M recommends not to get it on paint cause it may lift it good luck...Vernski
Old 05-29-2013, 07:48 PM   #12
sprinter11r
sprinter11r's Avatar
I went with the steele rubber after using the cheap stuff first. big difference and worth the money.
sprinter11r is offline   Reply With Quote
Old 06-04-2013, 12:38 PM   #13
idaho66stepside
idaho66stepside's Avatar
The cheap stuff happen to come from a popular resto parts company?
idaho66stepside is offline   Reply With Quote
