Old 06-08-2013, 10:15 PM   #1
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
What mounts?
Planning on trying to put a 4.8/5.3/6.0 (whatever I can get best deal on) in a 7-72 shortbed truck with factory crossmember. Before I make the frame all pretty what mounts should I use and with (your recommended mounts) do I need to drill non existing holes in the frame?
Pretty much what Im sayin is if I can get a good deal on powdercoat job I dont wana be drilling on it or something crazy like that.
What mounts do you recommend any why?
John
1999 Toyota Tacoma 4x4
Old 06-08-2013, 11:01 PM   #2
truckdude239
truckdude239's Avatar
Re: What mounts?
I used the dirty di go slinder mou ts got them prepowder coated for like 150 used the stock engine mount on it
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 06-09-2013, 12:29 AM   #3
68c10airstream
68c10airstream's Avatar
Re: What mounts?
Hi, i installed a 2001 5.3 in my 68 c10. I used the 2001 mounts for these reasons. back in the day gm made crappy mounts, (remember engines cabled to the frame to prevent uncontrolled acceleration?), replacement old style mounts from my local parts stores are sourced from india and are rock hard, newer vehicles are designed to address potential noise, vibration, and harshness, (nvh), so i made upside down "u" shaped perches with a thick plate welded to the "u". The cupped 2001 mount straddles the "u", has bolts to attach the mount to the "u" and this assembly bolts to the frame. I slotted the plate for forward and aft adjustment. This has helped me in these areas; headers have room around mount, low mount gm ac compressor clears (some aftermarket adapter plates had to be ground down to clear) and my engine doesn't feel like it is ridgidly mounted to the frame. Cheap to make, and no regrets, but did take some time. This was my overall take on the whole situation as i was a dealer mechanic for about 30 years Good luck, Brian Fuller
68c10airstream is offline   Reply With Quote
Old 06-09-2013, 12:45 AM   #4
truckdude239
Re: What mounts?
Lol we have the same last name Brian
David fuller
2000 Tahoe 5.3l 378
Old 06-09-2013, 10:04 AM   #5
oldman3
oldman3's Avatar
Re: What mounts?
airstream, could you throw up a couple pics of what you did...Jim
oldman3 is offline   Reply With Quote
Old 06-09-2013, 03:02 PM   #6
nlped
nlped's Avatar
Re: What mounts?
I used the CPP tubular stands, poly mounts and custom built adapter plates to place the engine in the appropriate location for my long tube TBSS headers. I also did add a CTSV oil pan so I won't have impact issues with the ground on my bagged '70 SWB.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 06-09-2013, 11:00 PM   #7
crazy longhorn
Fabricate till you "puke"
Re: What mounts?
The Dirty dingo sliders may be the slickest set ....set em where you need em For mine , I already have poly mounts on the 383, & plan to use them along with a set of Carshop brackets/stock stands. The engine is not done yet (need to lap the valves, replace seals & springs), so I cannot say on the fit as yet. There are many options, just consider all the parts on the build(eng placement,exhaust, ect). Eng placement 1st, then check the fit on the rest? Have fun, Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 06-10-2013, 07:54 AM   #8
Jon01
Jon01's Avatar
Re: What mounts?
Stock stands, Ebay $30 adapter plates.
Jon01 is offline   Reply With Quote
