Old 01-06-2014, 12:39 PM   #1
AngryPirate
AngryPirate's Avatar
Column mounted turn signal switch
So, I've been messing around with my stock turn signal switch that is a cable actuated unit on the steering column, under the dash.
These seem a little problematic as I've had to replace it twice. Am I missing something here or is this the reason everyone moves to the external, column mounted type like the one pictured below?
Thanks,
Scott
AngryPirate is offline   Reply With Quote
Old 01-06-2014, 01:02 PM   #2
tincan1966
tincan1966's Avatar
Re: Column mounted turn signal switch
Don't see too many switch to the Signal Stat type.
You can, however just change out to a '63-66 column. Those switches are easily available and dependable.
tincan1966 is offline   Reply With Quote
Old 01-06-2014, 02:51 PM   #3
AngryPirate
I guess I should've mentioned it's a '61. I'll look at the 63-66 switches. Thanks!
Old 01-06-2014, 04:23 PM   #4
AngryPirate
Dumb question here...can a 1961 steering wheel be used with 63-64 column?
Old 01-07-2014, 09:02 AM   #5
benwah
benwah's Avatar
Im thinking the 63-66 guts will fit our 60-62s.
benwah is offline   Reply With Quote
