Old 06-24-2013, 08:04 AM   #1
catch2otwo
How to find new alternator?
So my 68 gmc originally had a 327. The previous owner swapped in a 350. I need to buy a new alternator. How do I make sure I get the correct alternator at the parts store without bringing my alternator and putting it on the counter since this is my only vehicle.
catch2otwo is offline   Reply With Quote
Old 06-24-2013, 11:09 AM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: How to find new alternator?
I usually go to O'Rielly's website and check the parts for both engines. When you look up a part they have a compatibility tab that can be selected and it will tell what engines a part will fit.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 06-24-2013, 11:21 AM   #3
68gmsee
Active Member
68gmsee's Avatar
A pic of your alternator and engine setup would help (front and back). Here's a good article on id'ing them.
http://www.madelectrical.com/electri...elcoremy.shtml
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 06-24-2013, 11:25 AM   #4
cdowns
cdowns's Avatar
if only vehicle ?? how about driving it to autoparts store??
then if there is a question have them walk on out an have a look
Old 06-24-2013, 03:34 PM   #5
volksworld
I agree...charge the battery fully and drive there...its 2 bolts,change it in the parking lot .at least then when you get the defective one you can try another...or put in a regulator when it still doesn't charge....most parts houses cant look up the right one even when you're holding it
volksworld is offline   Reply With Quote
Old 06-24-2013, 03:58 PM   #6
WorkinLonghorn
WorkinLonghorn's Avatar
Get the regulator too.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 06-25-2013, 09:12 AM   #7
MARKDTN
Unless you just have to have stock, take this opportunity to swap to a later integrated regulator version alternator and ditch the old mechanical regulator. There is tons of info on this swap. You could also swap to an even later CS144 (stay away from CS130). There is much info on that swap too.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
