Old 06-24-2013, 08:43 PM   #1
tjsblazer
tjsblazer's Avatar
Moving ngine position on 4wd
Hey, I have been gathering parts to do a driveline swap to a 5spd. I had planned on moving the Engine ahead to the front holes (about 3 inches) to help with the overall driveline length and shifter position of the NV4500. I know that is where 2wd Engine crossmembers mounted from the factory. I am noticing now that the front differential is going to be very close now (probably why 4wd were set further back). All the threads I can find look like the trucks had lifts in them when they moved the Engine forward. I am planning on doing it with stock ride height. Has anyone else moved the engine forward to the 2wd mounting position on a 4wd truck with stock ride height?
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
