![]() Join Date: Aug 2004
Anybody got a CPP tubular trans crossmember?
Do you have one not installed? Can you make me a template of the mount?
Thanks guys! Posted via Mobile Device
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Re: Anybody got a CPP tubular trans crossmember?
Nobody?
TTT
Never Ending Projects
Actually I do. Sitting on my living room floor.
What did you need exactly?
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
I just need a paper template of the left or right mount, where it will mount to the frame. Ill be happy to pay you for postage and your time.
Artist
![]() Join Date: Jan 2010
Its pretty simple. 90 degree angle with a couple holes drilled in it and then the tube welded to that.
66 Chevy C10 283ci~cough~ SBW Fleet Buttercup '66 |
Could you measure the center to center on the bolt holes?
The holes are the same as the factory crossmember. Mine bolted right in, no drilling.
1965 Chevy Short Box Stepside, 230 - 3 speed, 4:11 gears, original paint rust free survivor. Now sporting a 383 SBC and TKO-600 |
Just measured my 2 days ago. The holes are 4" apart, center to center. Here is a picture of it installed.
Jeff Simplify Life! My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=566533 |
Thanks guys, I have one installed but cant get under the truck right now, its in the body shop getting a few "oops'" taken care of.
Oops normally equals $
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Yea I know. I just found 3 door dents that someone at work was nice enough to not tell me about. So this means no more driving to work except on Saturdays and holidays. Since I'll be the only one there.
