Burb Rear A/C in a Crew?
I'm back and forth about what I want to build for my next toy, either a roadster k5 on air, or a ls powered ccsb.
If I go with the crew, I'd like to add a rear a/c setup from a suburban. Has anyone done this? Posted via Mobile Device
74 C10 LWB 350/T5 Dropped on 20's Soon to be Bagged and Injected 84 C35 Crew Cab Dually. 454/400 Dropped a lot. Instagram: mmmdropp |
Re: Burb Rear A/C in a Crew?
After some l looking online, I don't think the burb setup would work without a ton of modding. So hmmm... Anyone have a good idea to get air to the back?
I have a complete rear AC setup I'm trying to sell should you'd like to try it, I'll be heading through Arizona in sept..
Zaccaglin 1998 Chevrolet C1500 Ext. Cab 350 Former Rig: 1985 Chevrolet K20 Suburban 6.2L Detroit/TH400/NP208 |
Anything can be done if you try hard enough,Only thing i see being a problem is trying to tuck everything in the back of the cab.You have any measurements on all the pieces?
I don't have any measurements, nor have I bought a cab yet. I just didn't realize the vents were all the way at the back of the suburban. I'd like to try and keep it simple, as a ccsb would probably end up being my dd, I know myself.
![]() Join Date: Oct 2006
I think the only thing you will accomplish is blowing cold air on the back of the drivers head. rear 'burb air box is BIG. Why not come up with a center console that plums air to the rear via the floor?
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
#7 | |
I just wish you could buy a high flow fan to move the air quicker... Cool down time seems long in a crew. |
After owning square burbs and a next gen burb, I have an idea. My 96 has rear air also. But it is totally different than the square. It has the vents right behind the driver. You can also put it on front or rear control, etc. Might be interesting to take a look at it.
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold ![]() 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
The 96 idea would be cool, especially if it has it's own control unit. I had thought of doing a console type too. It's all gonna come down to what I find first, a blazer tub or a crew cab body.
I think you'll be a lot better off building the rear AC setup yourself. Using bent sheetmetal welded together or something. I've considered doing this in a couple of older, longer vehicles that I want to fix up. Bout the only thing you'll get to use that's factory will be the vents, for looks.
