Old 07-29-2013, 02:14 PM   #1
mattpiotr
High Volume or Standard Oil Pump
I'm rebuilding a 350 4 bolt main motor to put in my truck the blocks a 69-79. Everything is all standard no boring. the motor has a mild comp cam in it and thats about it. its a 2500 truck I use it for a everyday driver. pull trailers, Plow snow with it and drive high ways. Before I start to put the motor back together I just want to see what oil would be better for me. a standard oil pump? or a high volume standard oil pump the motor has the 6 qt pan in it. The motor that is in there now when i do 75mph on the highway the oil pressure downs down to 15psi. I don't want this same problem with the new engine. Thanks
mattpiotr is offline   Reply With Quote
Old 07-29-2013, 02:37 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: High Volume or Standard Oil Pump
15psi isn't bad. My friend had a really old 350 that would idle at zero psi and get to 15 on the highway
But yes a normal pump will work fine. A standard clearance motor doesn't need any more than that
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 07-29-2013, 04:52 PM   #3
geezer#99
geezer#99's Avatar
Interesting rebuild. All standard, no boring!
New or old rings?
Hone for new crosshatch or not?
New bearings or original ones?
New or old cam bearings?
New or old lifters and timing chain?
A new comp cam though!
Standard or the original pump woukld work.
Old 07-30-2013, 02:14 AM   #4
mattpiotr
New or old rings?
Last I checked a rebuild involves rings and bearings.....boring needed on this motor just hone
Old 07-30-2013, 07:23 AM   #5
BigBlocksRule
Pressure is a function of resistance. Tighter bearing clearances = higher pressure. If you're down to 15lbs, you have clearance issues. New bearings generally take care of this - INCLUDING CAM BEARINGS!!! Most folks don't want to go through the hassle of having cam bearings replaced, but they're the culprit as often as mains/rods.
That said, standard volume/pressure is fine.
BigBlocksRule is offline   Reply With Quote
Old 07-30-2013, 08:28 AM   #6
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
For a piece of mind, install a BB oil pump. It only takes a little work to fit one. Remove the drive wheels. Smooth out inside to remove casting. A smooth inside pump works better to flow oil. Smoogthing the inside works for SB pumps too.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 07-30-2013, 01:10 PM   #7
INSIDIOUS '86
New or old rings?
Rebuilt the motor for my freinds Camaro and it was in such good shape we deglazed it and went std on everything. These good motors are still out there albeit hard to find. Try looking for mat 70s soft cam motors, cars and engines get parked when the flat cam so they stay low mile
Old 07-30-2013, 01:46 PM   #8
weaintscared
weaintscared's Avatar
Do it right, don't cut any corners and make it scream you will be happy then, I had to do the BBC think to be happy Check out my builds
My build http://67-72chevytrucks.com/vboard/s...d.php?t=468622
My other toy http://m.youtube.com/watch?feature=s...eature%3Dshare
weaintscared is offline   Reply With Quote
Old 07-30-2013, 09:44 PM   #9
kalbert
No need for a high volume pump at all. A standard will suit you fine.
kalbert is offline   Reply With Quote
