Old 08-14-2013, 08:52 PM   #1
plumber36757
Door problem
How many shims are used on a typical door. Any one have a clue. Top shims and bottom. Count please I'm trying to figure out a starting point.
plumber36757 is offline   Reply With Quote
Old 08-14-2013, 09:53 PM   #2
turp mcspray
turp mcspray's Avatar
Re: Door problem
Normally there is enough adjustment in the door, and hinges, that no shims are needed.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 08-15-2013, 07:40 AM   #3
Cape Codder
Cape Codder's Avatar
Re: Door problem
Grab the back of the door and lift up , if it moves up and down your hinges need rebuilding not shims.
Cape Codder is offline   Reply With Quote
Old 08-15-2013, 07:57 AM   #4
volksworld
Re: Door problem
normally the only shims are on the striker on the door post...I had some trouble with my upper hinge....the bolt heads on the door hit the hinge and wouldn't let it close completely...caused the door to sag...used thinner washers and ground the heads a bit to cure it...
1970 short step c10 leaf spring 454
volksworld is offline   Reply With Quote
