Old 08-01-2013, 10:20 PM   #1
Zable49
Zable49's Avatar
After the math
After doing the math and looking up piston #'s. Why would someone build an engine with 7.9 compression and drop it in a truck without running a blower or turbo? Talk about NO power. Guess i should start looking for a set of cheap pistons
1970 C20 Camper Special
SBC350 / TH350
'84 C20 Front Disc Brakes/Control Arms
Zable49 is offline   Reply With Quote
Old 08-01-2013, 10:25 PM   #2
54belair
54belair's Avatar
Re: After the math
85 or 86 octane gas?
1997 shortie stepside
1968 short stepside
1966 mustang
1966 chevelle ss
Dont always go the cheapest route--You can save yourself into the poorhouse!
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=489030
54belair is offline   Reply With Quote
Old 08-02-2013, 12:51 AM   #3
Zable49
Zable49's Avatar
Re: After the math
Nope This is Washington. 87 - 93
Originally Posted by Lattimer View Post
Possibly didn't know what they were doing, or they were building a blower motor and ran out of $$.
Hey maybe I can talk the wife into a blower.
Yeah ok thats not feasable on my budget. Guess it's new pistons.
SBC350 / TH350
Old 08-01-2013, 11:20 PM   #4
Lattimer
Lattimer's Avatar
Re: After the math
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 08-02-2013, 12:02 AM   #5
mmiddle
mmiddle's Avatar
Re: After the math
2x. Blower motor or stupid.
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline   Reply With Quote
Old 08-02-2013, 01:21 AM   #6
WIDESIDE72
WIDESIDE72's Avatar
Re: After the math
Are you sure they are aftermarket postons and not stock dished? What is the bore size?
WIDESIDE72 is offline   Reply With Quote
Old 08-02-2013, 01:25 AM   #7
Zable49
Zable49's Avatar
Re: After the math
The engine is bored over +60, and the PO said that he bought the engine from a buddy when he threw a rod in the original 350
SBC350 / TH350
Old 08-02-2013, 01:28 AM   #8
Zable49
Zable49's Avatar
Re: After the math
I guess the question is, should I pick up flat tops or slightly domed... I will be running stocker heads 76cc due to budget.
SBC350 / TH350
Old 08-02-2013, 07:03 AM   #9
Lattimer
Lattimer's Avatar
Re: After the math
Flat tops with 76cc heads winds up around 8 or 8.5:1. Will run well on regular and act like most stock 350's. With .060" over should be a nice running small block.
From there, you can probably get up to 9.5:1 depending on what you buy. Big limit is the stock heads, and you probably won't make a ton more power going any higher.
I'm almost done building a 327, .030" over with 291 double hump 62cc heads. Flat tops are calculating at 9.6:1 compression. I'm gonna have to run premium in it.
Shawn
Old 08-02-2013, 07:14 AM   #10
WIDESIDE72
WIDESIDE72's Avatar
Re: After the math
I have run flat tops pistons with old 461 double hump heads on 350's and 383's and a thick head gasket on 87 in the past but you cant run a lot if timing. I forget the details as my brother built it for me but it was a daily driver and remember i would add timing and run 91 octane on ocassion and it really woke up! I later switched to 64cc brodix track1 heads and it was alot more detonation proof due to the heads dissipating the heat better.
Old 08-02-2013, 07:16 AM   #11
WIDESIDE72
WIDESIDE72's Avatar
Re: After the math
I wouldnt run more than a flat top on the street with iron heads uess you want to spring for the extra octane and imo it wont get you much extra power in return.
