Old 11-29-2012, 08:04 PM   #1
Double Stack
Double Stack's Avatar
Coolant level dropping fast
Just bangin my head against the wall over here...
My problem is as fallows, my coolant level is always dropping. I'd say I need to add about a half a gallon of water every other time I drive it. Or say every 40 to 50 miles. I've driven it hard, and then checked for leaks. I've had somebody watch me drive away as I get on it, as i've read on here that it could be coming from a freeze plug under load as I get on it. I've pressure tested the coolant system and there were no leaks. It also held 12 1/2 lbs of pressure for like five minutes. There's no coolant/water in the oil. I also dropped a surge tank in the truck to see if it was pushing water out it overflow and not a drop was collected.
Talked to a guy I know that's pretty smart, and the best he could come up with is if i'm running mostly or all water in my coolant system it could be cooking off fast. I told him it seemed to doing it back when i was filling it up with a good mix of coolant too, but i've been running straight water for awhile now.
Anybody feel like being a GENIUS!?!
Double Stack is offline   Reply With Quote
